Distributor Timing Confusion
Old Oct 2, 2016 | 04:45 AM
MastaFlyMason's Avatar
Default Distributor Timing Confusion
I was trying to retard my timing on my distributor (d16y8 motor with d1y7 distributor if it matters). I had my pins jumpered and when I turned the distributor when I went all the way forward (as retarded as the timing could physically go) it was where it should be (in the middle of the 3 lines). I took the distributor off, and somehow when I put it back on it was opposite? Now when I jumpered it I had it fully advanced and that was right in the middle 3 lines. So I got my timing retarded the way I wanted, but how could it have possibly switched around? Could I have it on 180 out? Thanks
Old Oct 2, 2016 | 05:51 AM
Default Re: Distributor Timing Confusion
Just to be sure, if I wanted to retard my timing 4 degrees I would be right about here wouldnt I?
Old Oct 2, 2016 | 02:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The dog teeth of the distributor can be inserted 180 out. It shouldn't fit easily as they are offset but many users have done it before you.
Inspect the dog teeth for the offset and make sure it matched the offset on the camshaft end.
bnmm
Engine Management and Tuning
May 27, 2011 05:28 AM
tobster
Aug 20, 2010 05:55 AM
96a-ccord
Feb 26, 2010 02:04 PM
azzurribaggio
Jun 26, 2009 09:25 PM
