Slipknotko's Build thread: looking to build a 500hp "G"23
i have a new f23 block and h22 head ,. a t04e turbo 3" intercooler system, 550cc injectors, 74 mm skunk 2 throttle body, pro series h22 intake manifold skunk2. aftermarket fuel rail. forged f23 rods and pistons 86m bore with 97 mm stroke. aftermarket ecu cant remember what the tune shop put in. project to work on over the winter. any thing else i should be adding to make the build work / possible. 20 psi boost is where i want to be i think.
I guess I'm trying to understand. Is this a question about what you're missing, or a build thread you have started, or..... This is vague.
See comments in Red
a t04e turbo - We have no idea what that means. Measure inducer/exducer of the compressor & exhaust wheels to confirm
3" intercooler system, Umm is that the diameter of the I/C piping & intercooler inlet/outlet? Please be more specific. It sounds like an eBay system or Mishimoto
550cc injectors, - Maximum power rating for those is about 350hp to the wheels. That's about it. No way it will support 500hp either to the crank or wheels. You did not list a fuel pump nor mention what type of fuel you plan to use.
74 mm skunk 2 throttle body, - completely unnecessary for power reasons. It's only good to have it because you lost your stock one.
pro series h22 intake manifold - Helps with I/C piping fitment depending upon company purchased from. That's about it.
aftermarket ecu cant remember what the tune shop put in. - This is completely worthless. If you don't know the ECU, how do you know it's tuned? Why would you trust that when that company had no idea what you had as components or turbo size? This looks to be more of a BASEMAP and nothing else. Without better information for yourself. YOU WILL DESTROY YOUR ENGINE WITH THIS ITEM IN HERE!
You can't possibly know what PSI you need until you know more about the ECU, the turbocharger, and what your purpose or goal is. This needs to be rethought with better research on your end about your power goals, use for the car, and Tuning resources available to you.
3" intercooler piping yes. 2.5 " down pipe with 2.5" straight exhaust
as for the ecu the tune shop installed and handles the tunes/ dyno whenever i bring it in. im building it there dyno / tuning it .
T04E External Wastegate Turbocharger:
- Oil Cooled
- Journal Bearings
- 5-Bolt Downpipe Outlet Exhaust (Turbo Manifold) Flange:Standard T3/ T4 4-BoltExhaust (Downpipe) Flange:Standard T3 5-BoltIntake Inlet/ Outlet:3.00"/ 2.00"
- Compressor:Trim:55A/R:0.5Inducer/ Exducer (mm):50.50 / 76.00
- Turbine:Trim:73A/R:0.63Inducer:65.50 / 55.90
- Oil Cooled
- Journal Bearings
From those measurements I can safely say that it will not make 500hp to the wheels. Maybe to the crankshaft if enough boost pressure is used, but definitely not to the wheels, no matter what you do.
So, you're using 3" intercooler piping, with a 2.5" downpipe and exhaust system? Hmmm. Well, the 3" intercooler piping isn't going to hurt you, but it really won't help either, so if you already have it, than fine, just don't expect it to assist you in your goal.
Do you know what actual hardware/software that you're tuner is actually going to tune with?. I understand that they are the ones manipulating the software, but you also need to know the brand and type of ECU you're using. Hondata, Megasquirt, Crome (Moates Demon), AEM, etc. Without that, we also won't know whether or not the fuel and ignition tables are robust enough to support what you need.
On the Walboro 255, you can make 500whp, but only on actual Race fuel or Meth/water injection mixed with 93 octane. Other than that, you have to change that out. But won't assist you with 550cc Rochester/Lucas sized injectors. You must upgrade.
Thanks for that so if I'm not going to be able to make that much is there a point in spending more on things like titanium springs and retainers . Oil coolers . Should I have a new down pipe made that is 3" the turbo outlet is only 2 I think
The outlet is 2.5" generally, and that's only at the turbine flange. you can easily have flared to 3" if you get the right downpipe from the right company or have one made. Most reputable copanies have that option. But, that also tells me you don't know what turbo you have or what company. It does make a difference.
You need to know more. Spending $1800 on an ECU system means that you need to damn sure know what the hell it is you bought!
.. Start investigating what you purchased, because no ECU can help make 500whp if you don't have the rest of the hardware to support it.
Berst info you could possibly get right there ^
I would like to add that as far as I know, steel springs and retainers are fine up to a pretty high hp, and are more robust than they are given credit for, I dunno, just a thought.
So i have more information it's a Garrett 3071r 3" custom intercooled tubing and intake tubing skunk 2 intake manifold and throttle body 74mm .h22a head with skunk2 stock sized springs retainers valves guides etc. F23 block with stock shaft forged Pistons and rods with bearings . 1000 cc injectors . will this engine be able to handle 20 psi boost
PS stop talking PSI..... forget it exists, state a HP goal and leave "PSI" out of the equation its completely useless
What you're showing is a journal bearing hybrid of some sort, using a 65mm exhaust wheel in a "J" 11-blade profile, using some 46 trim compressor wheel with a 76mm exducer. You might make 400whp, but not by 20psi on any kind of fuel other than high-knock resistant fuel.
Anyway you can show a source of origin for this turbocharger you have? It's definitely not a GT3071R, that's for sure.
*EDIT* Never mind, I think I found it, unfortunately....If someone indeed told you what they gave you is a GT3071R, you were duped. I hope it's really not a "Speed Daddy" turbo.
T04E T3 T4 63 A R 57 Trim Turbo turbocharger Compressor 400 HP Boost Stage III | eBay
@OP
If you post some pics shodan should be able to tell you if its genuine or not, I honestly wouldnt bother with a EBAY turbo if thats truly what it is
Why would you bother making a G23? Save yourself the hassle and get a block that matches the head or vice versa. Keep it simple. If you want reliable horsepower there is literally no reason to use the F23 block since you're going to have to sleeve whatever block you use anyway. You can get a complete, running F20B for about $400 from an importer and save you all the trouble of the frankenstein bullshit. The F23 crank will drop right when paired with the F23 rods and you can bore it to whatever you want to match the H22 head you have once it's sleeved. Again, literally no reason to use the F23 block unless you're trying to cut corners and save a couple bucks. Hell you could even pick up an F20B and sell the head + internals and probably MAKE money while getting the block you need.
BMo Tuning
Jun 19, 2011 10:59 AM
