497hp 403tq h22?
Re: 497hp 403tq h22?
yeah don't know why it was tune to 6600, but i'm going to find out with my tuner.
specs:
port & polish head
1mm over size flat valves
dual springs and retainers
stock camshafts
jg adj cams
skunk2 pro intake manifold
74mm throttle body
1000cc injectors
h22 sleeved block
arais 9:1
eagle rods
oem oil pump
t/4 sc61 .82
custom top mount
3" catback
50mm turbo smarts wastegate
2.5 intercooler pipping
hks ssqv
s300 hondata
specs:
port & polish head
stock camshafts
jg adj cams
74mm throttle body
1000cc injectors
h22 sleeved block
arais 9:1
eagle rods
oem oil pump
t/4 sc61 .82
custom top mount
3" catback
hks ssqv
s300 hondata
specs:
port & polish head
stock camshafts
jg adj cams
74mm throttle body
1000cc injectors
h22 sleeved block
arais 9:1
eagle rods
oem oil pump
t/4 sc61 .82
custom top mount
3" catback
hks ssqv
s300 hondata
specs:
port & polish head
stock camshafts
jg adj cams
74mm throttle body
1000cc injectors
h22 sleeved block
arais 9:1
eagle rods
oem oil pump
t/4 sc61 .82
custom top mount
3" catback
hks ssqv
s300 hondata
Dont get so caught up in numbers. Dynos read so differently its rediculous. Take it to the track and get some trap speeds and that should give you a better idea of the power the cars making.
I will have pics and a video in the next few days.
It feels like a beast 4500 and up between gears no lag on a stock tranny will replace once It breaks lol.
So I found out why he tuned it till 6600 it turns out that the power drops at 6600, so my question is what do you guys think which turbo will be great for my setup that it will take me till 8500 with out my power dropping? My ride is a daly driver but I want high hp DD lol
Start simple. Do a boostleak test. Since you have a different intake manifold and throttle body. Id check those over real well. You can have leaks around a lot of other components besides piping. Injector seals, TB shaft seals, etc. Check it all.
official honda whore
with that power where its at you should make close to 550+ when revved out
is vtec working correctly, its the only thing i can think of that would hold power back that early on
who tuned this car?
who tuned this car?
I have a built H22 with a GT35 so it's right in there with your SC61. At 20-21 it makes 520 whp @ around 7400 rpm. Mustang dyno. Your setup would probably be good for
8,000 rpm++ if tuned properly. I ran a SC61 for a while and made around 460 whp @ 8,000.
i just found out he gave me the wrong dyno paper lol, and it went to 8000 but the turbo gave out , i just notice it today the blade is all chewed up im surprised it even my 497hp. i didnt even notice it when it was on the dyno i'm going to send it back in to precision this friday to have them rebuild it and retune it it wasnt his fault he's a great tuner well see in about 2 weeks
