93 civic ex auto to manual conversion
Old Aug 25, 2016 | 09:27 AM
almostlover000's Avatar
Default 93 civic ex auto to manual conversion
So I'm trying to convert my 93 civic ex 2dr coup automatic to manual. Now I know I need the trans, ecu, pedal, shift linkage, and shifter from the donor car. But what I'm wondering is if there is anything else I need to make it work. Also would the axles from the automatic one work with theannual one? Both my car and the donor are completely stock if that makes a difference thanks.
Old Aug 25, 2016 | 10:48 PM
MisereNoire's Avatar
Default Re: 93 civic ex auto to manual conversion
Check the stickies and look for the Guides section. There are a couple of really good guides that will answer just about every question you currently have.
Here Section 7 c
Old Aug 26, 2016 | 01:37 AM
DeviousJunez's Avatar
You're good with using the auto axles bud ! Glad to see another ex brother , After some research on doing some from 92-00 you can use your auto axles
Heres a link that may help https://honda-tech.com/forums/honda-...4pics-1337459/ Pm Luserkid with help i was just talking to him about my questions he answered all of them, Hes a good guy!
- SincerelyAn 00' Civic ex brother
Old Aug 26, 2016 | 05:47 AM
kp's Avatar
kp
OP is asking about a 1993 Civic, not a 96-00.
https://honda-tech.com/forums/honda-...no-no-2090074/
http://www.d-series.org/forums/diy-f...nual-swap.html
https://honda-tech.com/forums/honda-...ap-eg-1316692/
Old Aug 26, 2016 | 04:59 PM
98civdx's Avatar
Master Detailer
You need an auto to manual mount.
http://www.ebay.com/itm/like/162091236483?lpid=82&chn=ps&ul_noapp=true
Old Aug 28, 2016 | 04:25 AM
94EG8's Avatar
Seagull Management
The automatic axles are the same. When swapping the pedals the automatic throttle cable is different at the pedal end so either swap the pedal or keep the automatic gas pedal (using the automatic pedal and cable it's a bit springy) You don't really need the ECU either, automatic P28s are easily converted to manual if you can solder. As mentioned you'll need a swap mount or you'll need drill the spot welds out of the bracket welded to the passenger's side frame rail to remove it and then weld on the bracket from a manual Civic.
angrysmileyface
Oct 7, 2014 07:48 AM
angrysmileyface
May 22, 2014 11:55 AM
civicguy395
Nov 26, 2012 04:11 PM
coasttime
Aug 21, 2009 04:38 AM
freakasis
Jul 23, 2008 05:31 PM
