Help! What turbo will i get.
Old Jun 14, 2016 | 07:56 PM
yannibeee's Avatar
Default Help! What turbo will i get.
Hey guys! I will be starting to build my turbo engine soon. But before anything i would like to ask for your help on what turbo should i get and also feedback on the parts that im planning to use. My goal is around 550-600whp. Fuel will be on 100octane pump gas.
Turbo:
Borg s366sxe t4 .88 or precision-6266-ball bearing gen2
Wastegate turbosmart 60mm
Blowoff turbo smart raceport
Precision 750hp intercooler
Head:
Ferrea comp valves
Ferrea turbo valve springs
Ferrea valve guides
Ferrea valve keepers
Skunk2 pro1 camshafts
Intake manifold victor-x
Throttle body 70mm
Injectors ID 1300cc
Fuel pump walbro 450cc
GSR or Type-R head
Block:
sleeved 84x89mm
Arias 10.5:1 pistons
Eagle rods or pauter rods
Ecu
Hondata s300 v3
Old Jun 14, 2016 | 09:55 PM
TravisBiggie's Avatar
Default Re: Help! What turbo will i get.
I hate precision, so I'm going to say stay far far away.
S366 sounds like a winner (theyre 575$ shipped for the shelf one on ebay)
Old Jun 15, 2016 | 02:08 AM
yannibeee's Avatar
Guys and feedback or comment on my plan build?
Old Jun 15, 2016 | 02:43 AM
ls joker's Avatar
Loved
Lucks good. Is there a reason you wanted a t4 turbine housing
Old Jun 15, 2016 | 03:27 AM
yannibeee's Avatar
What will be a good housing?
Old Jun 15, 2016 | 04:58 AM
Schister66's Avatar
Man U FTW
Borg Warner S364.5 S300SX3 FMW S300 64.5/68 Billet 64.5 - AGP Turbochargers, Inc. Store
Borg Warner here as well. I used to run an S256 and it was a great little turbo ...and its still going strong 40k+ miles later
There are a lot of turbine options to pick from
Old Jun 15, 2016 | 05:38 AM
LightningTeg's Avatar
Community Builder
Those are massive turbos for 550-600whp. Both can do well over 750-800whp
Old Jun 15, 2016 | 05:39 AM
ls joker's Avatar
Loved
I pmd you back.
Would the s256 make it to 600whp. Would that be on the hotter end of effiency. Ive always wonder that.
Old Jun 15, 2016 | 06:34 AM
TheShodan's Avatar
Moderator
I pmd you back.
It's WAY out of its league by 600whp. Yes, it technically can, but everything else has to be perfect, including the weather, for that to happen.
There are a LOT of choices for that range of power that's efficient for under 2.4 litres. What he's looking at is just huge. With the turbine housing even larger.
I would easily go smaller. Not as small as a S256, but something in the 58lbs/min-70lbs/min range. No more.
Old Jun 16, 2016 | 05:20 AM
Schister66's Avatar
Man U FTW
This might be more size appropriate from the BW lineup
Borg Warner / AGP S261_RS Turbocharger - AGP Turbochargers, Inc. Store
92egkirt
Dec 5, 2011 02:09 PM
ryguy2588
Nov 3, 2010 06:20 AM
Sofakingtyte
May 15, 2008 05:26 AM
3M TA3
Oct 4, 2006 01:57 PM
Screamer
Oct 23, 2002 08:30 AM
