Oil squirter/cooler sleeved application
Hi guys, I am currently in the process of boring and sleeving a GSR block to 84mm. Upon sleeving can I still use the GSR's oil cooler and oil squirter systems? I am running 84mm Nippon P30 pistons(CAST) with a P72 head. Will I still be able to run the squirter or should I just block them off? This isn't a track build just a DD...thanks in advance!
You can still use the squirters as long as you're keeping the GSR crankshaft.
If you use the LS crank then you'll need to have them bent/tucked slightly, depends somewhat on the pistons how much that will require.
Sleeves shouldn't matter. Its the crank counterweights that interfere with the squirters and sometimes the piston skirt when a 89mm or larger crank is used.
Staying with the stock 87mm crank you should be fine.
Keep the squirters. They help reduce piston temperatures which is a good thing. Many believe they are primarily used for lubrication which is incorrect. They are intended to cool the piston.
Pyro hit the nail on the head here.
I am curious though why you're using Nippon pistons after going through all the money to have the block sleeved? it'll work, it's just oem type budget build stuff. almost a waste to sleeve the block just to slap nippon pistons in. you'd be better off using forged pistons with stock bored cyls.
OEMJDM
13
Feb 16, 2010 04:35 PM
magicguy
14
May 15, 2007 08:33 PM
JBBNJ609
11
Nov 11, 2004 11:40 AM
