99 DX hatch (EJ6) automatic trans - losing coolant and grinding noise
Honestly, guys---- I dont know where i should start this off, so i'll just ramble and ramble until some progress is made...
I have a 99 DX hatch (EJ6) in the shitty blurple color.
stock d16y7 engine, automatic transmission (yeah, ouch- i know)
Heres me issues....
I car drive the car fine.... in fact, i got her up to about 115mph on I95.... engine is all stock, with the exception of the new header/cat and a few misc parts that do not really affect performance.
Problem #1.
If i drive more than 20 minutes, which is every day, i lose significant amounts of coolant. No signs of a headgasket(*)
oil is clean,, no white smoke, however, after driving for a long time, my reservoir is filled to the very very top, and it bubbles constantly for 5 mins, as if it were a bong... sounds like one too.
The engine has reached the highest point of the temp gauge multiple times, which could very well be a warped head, or a HG
-Going further into this issue, is the smell of coolant in the car.
Turn the heat on; coolant smell.
Get out of the car for 15 minutes, and you can smell coolant from 5 feet away. ZERO puddles, visible leaks.
-Ran a radiator compression test- found a small leak where the previous owner did not correctly clamp a heater core hose. sadly, the tool was broken, and did not hold air for long enough to continue looking.
I want to go on a whim and say that this smell is caused by a heater core, but im not sure.
-AC blows extremely hot, when cranked up, and cold when set to cold. fan can be turned off, but i still feel air flowing through it. temp depends on where the needle was left off at. (its a very light breeze)
-Car will also start overheating when at a stoplight or in traffic after driving for 20 mins, but will go back to regular temps while driving.
i got so ******* sick of spending 10 bucks to fill it with coolant every other day, so im literally running 25% AF / 75% water. no, this is NOT why im overheating. it was doing this long before the ratio was changed.
NEXT problem #2:
Driver side grinding noise after anything over 2500rpm when the engine is hot.
nobody has had a remedy for this.
-I have checked my brake dust shield, which are rusty and very bent. bent them back, no resolve.
I've checked between the rotors for rocks- nothing-
-I DO want to say that my inner tie rod has lots of back and forth play, and is sepperated from the boot (i can manually twist it)
I have not received a confirmation that this is the cause of the noise.
Timing belt/pump should be changed very soon, as its been something close to 70k miles. sadly, im in a kind of tight spot for money, so ive been putting it off.
can water pumps make grinding/scratching/whirring/ old HDD spinning noises when theyre old?
Either way, there is a lot of help i could use help with.
I am planning on swapping to a b18/b20 within two months.
desperately need more HP, and i feel a full swap will solve most of my current issues.
Heres me issues....
Problem #1.
NEXT problem #2:
Rent a block tester kit from AutoZone and check whether the radiator fan runs when the engine is hot.
Does the grinding noise only occur when the car is moving?
-changed CTS, fan switch, thermo, and the radiator itself (which is probably clogged now from that "professional leak fix ****") -whatever, 1 year warranty from AAP
Yes, grinding only happens while the car is moving.
another noise i make note of, is when i first start the car in the day, about 15-30 seconds later, i hear a whinny / groaning noise... "WEEEEEEEEEEE----- WEEEEEEEEEEEEEEEEEEEEEEEEEEE"
the grind itself is a rattling/grinding/scraping noise. its VERY audible, especially in tight corridors / driving by parked cars. its quite embarrassing. I changed my old catalytic converter (had a p0420) which rattled and had broken catalyst, and that took the code away for good.
Ill check my dust shield again
Get the block tester kit.
The front brakes have a wear indicator. Check that. Could also be a bad wheel bearing. But do check for a bent wheel splash guard first.
BXPhoto
Aug 26, 2015 04:22 PM
sentinal02
Jun 17, 2011 09:43 AM
sw07tc
11
Dec 17, 2010 02:15 PM
