Need help determining oil line sizes etc.
Old Mar 17, 2016 | 05:43 PM
ramboPandA's Avatar
Default Need help determining oil line sizes etc.
Can someone explain to me what all these things mean like 10AN hose, -6AN, 1/8" NPT, 8 AN O-ring. I am going to buy the GE sandwhich plate adapter, but no idea what fitting sizes I need. I tried to look this up but can't seem to find the explanation. Ty
Old Mar 17, 2016 | 05:55 PM
2kdrift's Avatar
Default Re: Need help determining oil line sizes etc.
the bigger the an number the larger the hose
https://www.pegasusautoracing.com/do...ocID=TECH00096
NPT = stands for national pipe thread
the size "you need" varies but most likey will be using a -3an for your feed and you could get an adaptor to go from the 1/8" npt to a -3an line
its amazing what happens when you type things into google
Old Mar 17, 2016 | 08:15 PM
motoxxxman's Avatar
AN is actually #/16's of AN inch. 3AN is 3/16". the reason for the name though is AN fittings are a specific style of fitting unique in shape and connection method.
NPT is explained in the comment above, but it is a tapered pipe thread. it is NOT a bolt thread, and using bolts in NPT threads, or NPT fittings in bolt threads WILL damage both sides.
Old Mar 17, 2016 | 11:14 PM
2kdrift's Avatar
agreed HE just needs a 1/8 npt to 3an adaptor (or whatever size he needs for his turbo) I have a golden eagle sandwich as well, My setup requires a -4an tho (uncommon) in the honda world
Old Mar 26, 2016 | 09:18 PM
ramboPandA's Avatar
Yeah I tried to google what AN means, nothing came up lol so thats why i came here,
Old Mar 26, 2016 | 10:17 PM
2kdrift's Avatar
No problem the name gets thrown around alot, some people dont understand that it references a style of fitting, my search was "an sizes" or something like that.
Pretty sure you will need a -3an line with at least (1) 1/8th npt (male) to -3an (male) adapter, most likely 2 of those depending on what your turbo calls for, just let us kno if u need more help
092eg6
Aug 2, 2010 01:18 PM
torqueless
Dec 8, 2005 09:04 AM
FOrSfEd
Sep 4, 2004 09:55 AM
phiberoptik
Feb 12, 2004 09:11 AM
GSR x13
Dec 2, 2003 10:11 PM
