how to tell the difference on oil feed lines.
Old Jul 28, 2010 | 09:27 AM
092eg6's Avatar
Default how to tell the difference on oil feed lines.
how do i kno if i have a -3an or -4an oil feed line? I have a oil feed line i thought was a -3an and a buddy came over and said it was a -4an line. how do i kno which one it really is? need to get a restrictor so i need to kno which line i have. thanks!
Old Jul 28, 2010 | 12:28 PM
dpetro1's Avatar
Default Re: how to tell the difference on oil feed lines.
Old Jul 28, 2010 | 12:47 PM
092eg6's Avatar
Originally Posted by dpetro1
lol like i kno
Old Jul 28, 2010 | 01:05 PM
EsotericImage's Avatar
Retired Moderator
so just buy a -3 line if you cant read measurements
xenocron.com has em cheap and already assembled.
Old Jul 29, 2010 | 06:41 PM
092eg6's Avatar
wel i just measure the size of the oil line with a micrometer and it was 0.328"
is it a -3an oil line?
Old Jul 29, 2010 | 06:48 PM
Retired Moderator
did u measure OD or ID?
Old Jul 29, 2010 | 07:00 PM
SpeedFactoryRacing's Avatar
Its also important to know what size you should be running. Most turbo manufacturers will have a specific size line requirement.
Old Jul 30, 2010 | 07:27 AM
092eg6's Avatar
not sure what od and id means but i just measure in the middle of the line.
Old Jul 30, 2010 | 08:26 AM
93egboosted's Avatar
od= outside diameter
id= inside diameter
Old Jul 30, 2010 | 11:03 AM
092eg6's Avatar
i guess i measure the O.D. then. i measured it couple times again and got 0.328" to 0.344"..... it does not match any of the numbers thats listed in that graph.
Old Jul 30, 2010 | 11:13 AM
g-gameslude18's Avatar
Thats because the chart is referring to the inside diameter of the hose. You will have to cut it open if you want to know what size it is or some how figure out how thick the tube wall is.
Old Jul 30, 2010 | 11:50 AM
092eg6's Avatar
u mean im not suppose to measure it with the stainless steel on the outside?
Old Aug 2, 2010 | 06:01 AM
dpetro1's Avatar
the chart is telling you to measure the diameter of the fitting on the end of the line, so you dont need to cut anything. most likely you have female threads on the end of the line so measure the inside of them
Old Aug 2, 2010 | 08:36 AM
B R Fittings's Avatar
Take the line with you to your local hardware store, and try screwing it to different size fittings to see what size you have.
At the hardware store the fittings will be called JIC and not AN. They are the same type of fitting though. Here's how to convert from one to the other.
-3 AN = 3/16" JIC
-4 AN = 1/4" JIC
-6 AN = 3/8" JIC
-8 AN = 1/2" JIC
-10 AN = 5/8" JIC
-12 AN = 3/4" JIC
-16 AN = 1" JIC
Old Aug 2, 2010 | 01:18 PM
092eg6's Avatar
-3 AN = 3/16" JIC
-4 AN = 1/4" JIC
-6 AN = 3/8" JIC
-8 AN = 1/2" JIC
-10 AN = 5/8" JIC
-12 AN = 3/4" JIC
-16 AN = 1" JIC
ok cool, this helps out so much, cause i was at OSH yesterday and got a fitting to fit onto my line, the fitting was a 3/16" fitting so that tells me i have a -3an oil feed line. thanks everyone!
gooberguy31
Feb 25, 2009 12:09 PM
mrx
Oct 30, 2005 09:08 AM
beepy
Mar 1, 2004 09:26 PM
delux247
Dec 27, 2003 02:00 PM
