Starter or Ignition Switch?
Got in my car and turned my key this morning and nothing happened. No sound or anything, but the dash lights went on.
Finally pushed the key again and it started right up. Drove it to work with no problems once started.
Something is definitely wrong, just not sure which one. Does this sound like a starter or ignition switch problem?
1998 Honda Civic LX 5-speed.
A third-party company (Mitsuba?) makes the starters, and Toyota used the same or very similar one on many cars.
I think it is called the clutch interlock switch. You can unplug the switch and put a jumper wire in the plug to bypass it, it will start whether you press the clutch pedal or not. If the car has cruise control, there will be two switches on the clutch pedal, the one at the top is for the starter.
I've had what sounds like the exact problem in my recently swapped B16A into my Del Sol. I heard a slight difference in sound between on and off the clutch turning the key while testing it so that is moving me towards the starter. Hopefully its the $20 option.
Except either my battery or alternator is dead. Not sure which. I managed to jump the car and take it for a twenty minute ride and all was good but when I turned it off it wouldn't restart.
carve
Sep 12, 2009 09:35 PM
