Starter or Ignition Switch?
Old 02-24-2016, 06:15 AM
roxics's Avatar
Default Starter or Ignition Switch?
Got in my car and turned my key this morning and nothing happened. No sound or anything, but the dash lights went on.
Finally pushed the key again and it started right up. Drove it to work with no problems once started.
Something is definitely wrong, just not sure which one. Does this sound like a starter or ignition switch problem?
1998 Honda Civic LX 5-speed.
roxics is offline
Old 02-24-2016, 06:30 AM
Fish Twig
tony_2018's Avatar
Default Re: Starter or Ignition Switch?
5sp, or auto?
tony_2018 is offline
Old 02-24-2016, 06:47 AM
Former User's Avatar
Check the rubber stopper that presses on the starter switch located at the top of the clutch pedal.
Former User is offline
Old 02-24-2016, 08:40 PM
red96turbols's Avatar
If it's the starter rebuild it. You can get the contacts from Toyota and fix it for less than twenty bucks and an hour of your time.
red96turbols is offline
Old 12-08-2017, 11:31 AM
roxics's Avatar
How do you do that and why Toyota? Is that a Toyota part?
roxics is offline
Old 12-08-2017, 11:32 AM
roxics's Avatar
I think it's this switch, not the stopper. Do you know what they are called and how much they are to replace?
roxics is offline
Old 12-08-2017, 12:47 PM
mk378's Avatar
A third-party company (Mitsuba?) makes the starters, and Toyota used the same or very similar one on many cars.
I think it is called the clutch interlock switch. You can unplug the switch and put a jumper wire in the plug to bypass it, it will start whether you press the clutch pedal or not. If the car has cruise control, there will be two switches on the clutch pedal, the one at the top is for the starter.
mk378 is offline
Old 12-10-2017, 12:07 PM
agentgordon27's Avatar
I've had what sounds like the exact problem in my recently swapped B16A into my Del Sol. I heard a slight difference in sound between on and off the clutch turning the key while testing it so that is moving me towards the starter. Hopefully its the $20 option.
agentgordon27 is offline
Old 12-11-2017, 10:14 AM
roxics's Avatar
Thank you. Hard to get to but I managed to clip the wires and splice them together. Works.
Except either my battery or alternator is dead. Not sure which. I managed to jump the car and take it for a twenty minute ride and all was good but when I turned it off it wouldn't restart.
roxics is offline
Old 12-11-2017, 06:59 PM
Stancetard Hate Monger
eghatch9295's Avatar
battery. alternator provides charge to battery while running. bad alternator= dies out while running.
eghatch9295 is offline
Old 12-12-2017, 11:42 AM
roxics's Avatar
Yeah that's what I thought. I already had the alternator replaced five years ago. The battery is much easier to get to.
roxics is offline
Old 10-29-2018, 10:14 AM
Mattbmenifee's Avatar
Hahaha not sure what to say but I'm 100% sure that Honda and Toyota are different auto makers last time I checked.
Mattbmenifee is offline
Honda knowledge
04-08-2015 09:27 PM
slq576
11-19-2013 07:50 PM
76 camaro car
05-28-2011 12:40 PM
KleanEj1
13
12-30-2009 02:43 PM
carve
09-12-2009 09:35 PM
Quick Reply: Starter or Ignition Switch?
