Idle problem, help !
Old Jan 9, 2016 | 09:56 PM
BuiltF22's Avatar
Default Idle problem, help !
My 91 Accord started making a really loud, high pitch noise a couple weeks ago that hurts your ears when the hood is open. In an attempt to fix this noise I thought I had found a vacuum leak on the egr valve. Since the egr was brand new and had been replaced a bit before I got the car, I decided to just clean it with some parts cleaner, replace the gasket and vacuum line. Now it fires up but almost immediately dies or idles super low at 500rpm and shakes really bad like its choking and will eventually die if I don't give it some gas. I made sure all vacuum lines and connections were secure and correct. I have no idea what's causing this. Any suggestions as to what could be the problem ?
Old Jan 10, 2016 | 03:54 AM
poorman212's Avatar
Default Re: Idle problem, help !
For giggles....what happens to the idle if you remove the vac line from the egr?
_Tim
14
May 9, 2009 03:30 PM
b16a4
22
Jun 1, 2007 02:37 AM
DA9teg93
May 9, 2005 12:12 PM
galioth
Oct 28, 2004 03:47 PM
Bictorious
Feb 27, 2004 09:45 PM
