Can you use an oil filter relocation kit for your turbo's oil supply?
Old Nov 6, 2002 | 11:55 AM
2000GSRT's Avatar
Default Can you use an oil filter relocation kit for your turbo's oil supply?
I came across this at overboost.com:
"Your stock cooling system can usually be teed off with radiator hose and redirected through the turbo to supply coolant. Oil on the other hand will require a certain grade of hose that withstands much higher temperatures. Fittings will need to be created both in your oilpan for the oil drainage line from the turbo and in a source of fresh oil somewhere before the turbo. The easiest solution for that (since most engines require tapping to get a live oil feed) is to install a remote oil filter relocation kit. These attach where your oil filter normally is, re-route the oil to a remotely mounted oil filter, and provides a return line back to the block for the filtered oil. This is the perfect place to tee off the connection and run a line to supply oil to your turbo. Your average kit will run you about $100."
Could you buy one of these and not have to tap into your oil pan???
Old Nov 6, 2002 | 12:02 PM
Brian_92GSR's Avatar
New User
Default Re: Can you use an oil filter relocation kit for your turbo's oil supply? (SuperchargedGSR)
No, that is only for you oil feed line. You have to tap into the pan to drain the oil no matter what.
Old Nov 6, 2002 | 12:05 PM
falcongsr's Avatar
What is this crap?
hmm yeah its a bad idea.
Old Nov 6, 2002 | 12:11 PM
20lb.teg's Avatar
Default Re: Can you use an oil filter relocation kit for your turbo's oil supply? (Brian_92GSR)
Well, not to be just unagreeable (if that's a word???) but WHY? it would seem that you take the relocation kit, run it to the filter, then trom the filter to the turbo and back to the in line of your oil relocation kit... That's how it works with your oil filter relocation kit anyways goes somewhere else (to the filter) then back into that same place...! That's how the oil filter relocation works in stock form and works perfectlly!!!! All you would be doing would be adding another (thing in the line) like the filter...
Well this is actually pretty smart, I never thought of something like that... Whoever thought of that has a good way of thinking of things...!
Later,
Sean C.
Old Nov 6, 2002 | 12:15 PM
sutrusu's Avatar
Default Re: Can you use an oil filter relocation kit for your turbo's oil supply? (20lb.teg)
wont work
oil return works by gravity. that's why the lines are short, un kinked, and pointingn straight down.
Old Nov 6, 2002 | 12:34 PM
VTC_CiViC's Avatar
The oil filter relocation would be ok to supply oil to the turbo I suppose, but you still have to return the oil from the turbo to the pan.. or did you mean run the expeled oil from the turbo to the oil filter relocation kit (to the motor side)? In which case I would wonder if there's enough pressure in the line to return the oil to the filter lines..
Old Nov 6, 2002 | 12:40 PM
falcongsr's Avatar
What is this crap?
Default Re: Can you use an oil filter relocation kit for your turbo's oil supply? (VTC_boost-less_CiViC)
the problem is that the oil filter relocator makes ALL of the engine oil go thru the relocator. if you put the turbo on the other end, the turbo would be blocking ALL the engine oil, as it flows very little oil compared to the rest of the engine.
am i missing something here?
Old Nov 6, 2002 | 07:16 PM
tony1's Avatar
Default Re: Can you use an oil filter relocation kit for your turbo's oil supply? (falconGSR)
Won't work for the return, don't bother trying. The return only works off gravity and any restriction will lead to many turbo problems. Just do it the old skool right way.
Old Nov 10, 2002 | 06:38 PM
20lb.teg's Avatar
Ahh, ok, thanks...That seems to make sense... See tha'ts why I like this board, if you go out on a limb and ask something (most of the time) people will first tell you why it will or won't work. Then they'll flame . What I'm trying to say is thanks for clearing it up for me anyway...
turbotime
Oct 20, 2006 12:03 PM
JDMTurboCivic11
Oct 26, 2004 07:18 AM
Xerxes
Aug 28, 2004 02:02 PM
15psi of fun
Feb 4, 2003 10:17 PM
rice4life
May 9, 2002 06:57 AM
