Fuel pump not turning on. 99 ex b20vtec
Old Dec 5, 2015 | 12:32 PM
arrocha87's Avatar
Icon4 Fuel pump not turning on. 99 ex b20vtec
1999 Honda Civic EX coupe
B20vtec turbo
Hondata S300 p28
Was adjusting tune and accidentally moved map selection over to an aftermarket one. And obviously the car died. No boggie I thought. Moved map back to stock and tried to start car but fuel pump not coming on. Turns over and checked the fuel settings and nothing weird. Any ideas before I pull seats? I checked fuse is good and receiving power. Next I'll check relay and then pump but was wondering if I'm missing something. Oem pump.
Update: checking main relay harness, I have power at pin 7 and pin 5. With ignition on I get power at 6 and none at 4, exempt it seems to jumper and hear pump prime. Really strange.
Old Dec 6, 2015 | 09:35 AM
arrocha87's Avatar
Default Re: Fuel pump not turning on. 99 ex b20vtec
So tried my friends p28 s300 and car primes and starts right away. Openes my ecu and nothing noticibly burnt. I'll check to see if pin 7 of connector A is outputting when I turn ignition on.
Old Dec 7, 2015 | 10:46 AM
Former User's Avatar
Your ECU or ECU chip is bad.
jdmAccord210
Engine Management and Tuning
Oct 22, 2013 11:22 AM
Hiboost 2.0
Apr 29, 2013 12:09 PM
pschum
51
Jul 24, 2011 02:43 PM
Galan
May 21, 2011 03:55 AM
the_dxB16
Dec 16, 2008 06:56 AM
