ek with a gsr swap wont rev higer then 6000rpm
96 ek hb with a gsr swap no codes at all with a p72 obd2 all stock will not go pass 60000rpms I tride my friends p28 chip with a jumper harnes and it will not go pass 5500rpms that's. Wen his vtec injages please help
318 Curves, 11 miles
Re: ek with a gsr swap wont rev higer then 6000rpm
Check your wiring and also check to see if your obd system is functioning correctly. Does the check engine light come on briefly before you start the vehicle? It could also be a funky corrosion/connection issue with your dizzy.
Yes. 90% of the time things like this are as easy as scewing the gas
cap back on until you hear three clicks or even checking to make sure your oil is at the right level. Without enough oil, the oil pressure light would flicker and disengage vtec everytime with a sputter and a loss in rpm's. I hope that's not the case though because you'd be out some money for a bottom end :/
It just to have the check in engine ligth. But I went to the autopar and scand it it was a o2 sensore and mis fire but I fixt it. And still dos the same whit no check ingine light
I both a jumper harnes and a p28 chip and still did the same ting but know it won't go pass 5500rpms cause that's wen vtec injeges with this chip
could be ur cluster too.. my buddy had an ls swap civic and it wouldnt go past 5600 rpms and so he switched out the cluster and that was the problem. now he can go all the way to redline no prob..
lies...I have a 99 civic hatch with a gsr and the throttle cable was way longer and it worked perfectly until I went with an LS throttle cable.
