F20B OBD2B to OBD1 Ecu conversion
Old Nov 29, 2015 | 12:06 PM
MajdiBerjaya's Avatar
Default F20B OBD2B to OBD1 Ecu conversion
Hello and good day. Today i just done converting F20B DOCH PCB-004 obd2b stock ecu to obd1 P30-003. Convert 3 wire IACV to 2 wire IACV with adapter plate. Bypass VTP A4-D6 with jumper wire and disable in crome. No check light, and steady idle now.
Using H22a basemap - engine crank but cannot start the engine.
Using B18c basemap - engine can start and have steady idle.
Do a datalogging on idle only, AFR is lean about 17.70 reading. So i do adjust fuel map until i get idle around 15.xx.
Question is, can i used b18c timing to run and tune f20b engine? Need suggestion or any basemap that safe to start tuning the f20b engine.
FeRReTTi
Jun 16, 2015 03:53 AM
pmey
Oct 10, 2008 07:53 AM
HondaTeg95
Apr 20, 2006 01:11 PM
vr_civic
Jun 15, 2005 06:03 AM
kyden
Dec 3, 2004 09:00 AM
