99 Civic EX Drum Wont Fit Back on After Replacement
Old Oct 6, 2015 | 06:17 AM
gillo_2014's Avatar
Default 99 Civic EX Drum Wont Fit Back on After Replacement
Hey everyone, I recently did a complete drum/shoe/cylinder replacement on my 1999 Civic EX and while it went smoothly enough but I noticed that I can't fit the drum back on the rear driver side. The cylinder is fine, there is no brake fluid in the lines but for some reason the brake still looks to be engaged for some reason. I've checked the e-brake, made sure the shoes are seated properly and centered and I have no idea what else could be causing them to be sticking out far enough to interfere with seating the drum.
Thanks for the help.
Old Oct 6, 2015 | 06:37 AM
rovafa2002's Avatar
Default Re: 99 Civic EX Drum Wont Fit Back on After Replacement
You definetly need to close your star adjustment so you can put it back in. Used drum will for sure have a bigger diameter.
Old Oct 6, 2015 | 06:58 AM
gillo_2014's Avatar
The star adjuster was/is completely closed when I put it back in. I also tried to see if the older drums would fit over it but the shoes seem to be slightly beyond there limit, like someones holding the brake down but it wasn't anything like this on the passenger side drums/shoes.
Old Oct 6, 2015 | 07:28 AM
tony_2018's Avatar
Fish Twig
its not centered, thats for sure.
Old Oct 6, 2015 | 10:48 AM
EsotericImage's Avatar
Retired Moderator
///Nick
Jan 22, 2012 05:56 PM
jarven93
Sep 30, 2009 11:33 AM
BlackEG6
Apr 9, 2006 09:51 PM
tomaseuro
Oct 17, 2005 02:05 PM
