95 ex Brake Question
As long as I dont have to take out any more Metal Gears
Re: 95 ex Brake Question (BlackEG6)
Yes it will fit no prob. U should also plan to upgrade the rear to disc as well. With those brakes u will have a large nose dip when u brake. I believe your CX comes wiht the same prop valve as the 99-00 SI, so that doesnt need to be changed. But u may want to change the master cylinder to a 96-00 EX or 99-00 SI. That part bolts right on no probs.
I have a 97 LX with 99 integra full brake setup, with 99-00 civic SI prop valve, 00 civic EX 7/8" master cylinder, and SS brake lines. Pedal feel is stiff and responsive, and I didnt change the brake booster either. Good luck with your project
Re: 95 ex Brake Question (rukawa1one)
well i got these because my right hub went out and i was told that i had to replace it. so i picked both of these up for 150 and was wondering if they fit. sum1 told me they would but im jux making sure. can never be too careful
yea they fit i have a 94 ex coupe and i just put 2001 gsr front and rear disc on to my coupe no prob ..and 94 -01 integra suspension will work also also ek suspension except the rear control arms...i suggest you upgrade 2 rear dis especially u have a swap i just did mine last week and it is awesome totally responsive i feels safer and i can slow down no prob without down shifting!
Jon Petersen
03-30-2018 08:48 PM
EJoneuglyhonda
09-29-2013 10:44 PM
