Jumps and cutting out b20v
I just put a b20v in my integra92. I'm running the stock ecu with a b16 head. It has a ls trans 70mm throttle body. And also using a ls dizzy. It runs fine but ounces it is driving and hits 2 grand it starts jumping and cutting out. Could it be the dizzy???
Bouncing around, probably backfiring.
I checked the part #'s for the distributor between the ls and gsr, they are definitely different. But that could be because of the housing bolt hole are different. The internals should be the same.
