LS/VTEC
Old Sep 17, 2003 | 11:55 AM
I 8 1 U 8 1 2's Avatar
Default LS/VTEC
i have a 96ls with a 99si head. the shop that did the swap for me left the ls distributor on the car, can i use this distributor or not? i'm running rich and i checked the timing its perfect and i swaped the ecu out with another one same thing!!! i'm getting like a poping out the exhaust. someone told me u can not use the ls distributor for some reason , if anyone has any info i would love to here
THANKS
Old Sep 17, 2003 | 12:26 PM
redlinegsr's Avatar
Default Re: LS/VTEC (I 8 1 U 8 1 2)
get an si distributor it should correct your problems...are you getting any hesitation when you hear this poping moise?
Old Sep 17, 2003 | 12:37 PM
Default Re: LS/VTEC (redlinegsr)
can u tell me what makes the distributor cause this problem. the answer too the question is no but i feel that i'm chocking a little bit. car runs strong though
Old Sep 17, 2003 | 02:12 PM
91integraLSVTEC's Avatar
i'm using an ls distributor on my ls/vtec, only one bolt holds it in place.. no problems..
Old Sep 17, 2003 | 02:21 PM
mr.beeks's Avatar
Default Re: LS/VTEC (91integraLSVTEC)
that little poping noise sounds like your sensor inside the
distributor is bad so change distributor but
the only thing you have to worry is about the plug if its obd1 or two
otherwise the base will not line up with the head
but it will work..
Old Sep 17, 2003 | 04:23 PM
teg2nr7's Avatar
Default Re: LS/VTEC (big reds)
How much was the labor cost about on the ls/v-tech head swap??
Old Sep 17, 2003 | 07:12 PM
ggangtong81's Avatar
Default Re: LS/VTEC (teg2nr7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg2nr7 &raquo;</TD></TR><TR><TD CLASS="quote">How much was the labor cost about on the ls/v-tech head swap??</TD></TR></TABLE>
do it for yourself. not so hard to do it. follow the instruction, and u will bef ine.
Old Sep 17, 2003 | 08:36 PM
teg2nr7's Avatar
Default Re: LS/VTEC (ggangtong81)
y do they only call it an LS/V-tech head swap b/c the RS has the same engine so cant u do it to an RS too?
Old Sep 18, 2003 | 02:03 PM
VTECorona's Avatar
Most people with B18B's have an LS I guess. Yes, you can do it on either GS/LS/RS.
jdmb20bvtec
Apr 10, 2008 09:59 AM
orangehatch
Jun 13, 2006 05:18 PM
Fastwhip
Apr 11, 2006 12:58 PM
Nighthawk GS-R
Sep 12, 2003 01:06 PM
1EK1EG
Nov 19, 2002 12:41 PM
