D16Y8 Head on Y7 block
Old Sep 27, 2015 | 01:50 AM
Bleakened's Avatar
Icon5 D16Y8 Head on Y7 block
I've read over a dozen threads but I seem to be confused on something...
98 DX hatch with a 100% stock Y7 motor in it. Auto transmission. If doing a Y8 vtec head swap, which intake manifold would I want to use? I have read about some of the differences between the auto and the manual one and about sensor mounting points on them and all but am confused one which one would be used.
To make this swap work correctly, which intake manifold (and what year) should be used for this with the auto tranny? And what TB should be used? Y8 or keep the Y7? And last but not least, would the automatic ECU matter if it's 96-98 vs 99-00?
Thanks.
Old Sep 27, 2015 | 07:56 AM
Former User's Avatar
Default Re: D16Y8 Head on Y7 block
96-98 OBD2a P2P auto ECU
96-98 auto Y8 IM and TB
Old Sep 27, 2015 | 09:20 AM
eghatch9295's Avatar
Stancetard Hate Monger
vtec ecu will not run the y7 a/t correctly.
Old Sep 27, 2015 | 12:03 PM
Right. The ECU will throw transmission codes. OP would also need to install a knock sensor.
Old Sep 27, 2015 | 05:54 PM
in other words, op, don't bother unless you plan to swap to manual. a y8 intake manifold will help a bit, as will converting to an actual exhaust manifold/ under car cat converter instead of the horrible cat manifold you have now
Old Sep 28, 2015 | 12:01 PM
Bleakened's Avatar
Yeah, not going to bother with any of it knowing all this. Thanks!
G Jones
Nov 17, 2023 12:16 AM
xbeamelite
Apr 21, 2008 05:48 PM
DBOT
Sep 20, 2005 10:39 AM
Civiclx
16
Apr 29, 2004 09:04 PM
TheAutoboxer
Apr 26, 2003 03:21 PM
