Suspension & Brakes Theory, alignment, spring rates....
Question on loose retainer ring on front LCA (Integra)
Old Jun 28, 2015 | 08:55 PM
codenamezero's Avatar
Default Question on loose retainer ring on front LCA (Integra)
Quick summary: Purchased an aftermarket front LCA from a shop off Facebook, however, the inner LCA (part where it bolt onto the frame) retainer ring was too small, so the stock bolt won't fit through. After much hassle, the seller shipped me a new set of retainer rings, so I pressed out the existing one and put the new one in, however, the new ones are a little bit loose, maybe ~1mm too small (the bolt fits perfect now).
Question: Will this cause an issue? Can I maybe get some polyurethane caulking from HomeDepot and fill it up?
Old Jun 29, 2015 | 04:29 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Question on loose retainer ring on front LCA (Integra)
Retaining? Ring?
Pics?
Old Jun 29, 2015 | 04:35 AM
egsleepercivic's Avatar
post a pic of what you are talking about, sounds like these LCA belong in the trash
Old Jun 29, 2015 | 07:27 AM
I'll take one when I get home, but it's the metal "collar" that goes inside the bushing
Old Jun 29, 2015 | 09:03 AM
98civdx's Avatar
Master Detailer
the ring that goes inside the bushing is loose?
sends the pieces of **** back.
Old Jun 29, 2015 | 10:11 AM
https://goo.gl/photos/M6KJSiruuJ9LJPqs5
I can't send the piece back, I am stuck with it. And I won't be doing any business with that guy, nor off Facebook ever again.
Old Jun 29, 2015 | 01:55 PM
B serious's Avatar
polyurethane bushings.
Yes...you will have issues with 1mm of slop if its between the bushing and the sleeve.
Old Jun 29, 2015 | 05:57 PM
cruizinmax's Avatar
Yes it will cause an issue. No you can't fill it with caulk. You would be better off having the sleeve machined out to fit the bolt you are trying to put through it.
Old Jun 30, 2015 | 08:06 PM
98civdx's Avatar
Master Detailer
Really at this point the only options I can see are, see if you replace with other bushings. Possibly ES, or rubber bushings.
Old Jul 1, 2015 | 08:37 AM
any specific reason you are using aftermarket LCA and not OEM ?
Old Jul 1, 2015 | 08:46 AM
burnoutboy's Avatar
The Credible Hulk
Front LCAs should be OEM, Hardrace, or nothing.
Rears I'd say OEM, Function7, Hardrace, MAYBE Skunk2, or nothing.
EVERYTHING else will wear out prematurely.
Old Jul 1, 2015 | 06:51 PM
cruizinmax's Avatar
Or you could use the bushing sleeve that came with the control arm (the one that fit the bushing) and bore out the hole in the middle to fit the bolt.
Q, is the subframe in your car from an EK? I thought the EK took the same lca as an integra/eg except the EK uses a larger bolt for the lca to subframe.
Dann6968
11
Jul 15, 2012 07:19 AM
swizz977
25
Dec 31, 2011 02:00 PM
HotCheetos
Dec 11, 2010 05:12 PM
seed2harvest
Honda Civic (2006 - 2015)
22
May 22, 2007 01:45 PM
rdaggett
26
Apr 12, 2005 09:37 AM
