rear upper arm bolt question for 1992 civic
Old 12-31-2011, 09:56 AM
swizz977's Avatar
Default rear upper arm bolt question for 1992 civic
ok my question is how do these bolts actually tighten because mine wont.. is there a nut welded on the inside of the frane thats messed up? or is there stripped threads on the inside where the bolt goes in?
swizz977 is offline
Old 12-31-2011, 09:58 AM
The Grumpiest
grumblemarc's Avatar
Default Re: rear upper arm bolt question for 1992 civic
There is a welded nut. If yours won't tighten then it probably broke off. Bad for you.
grumblemarc is offline
Old 12-31-2011, 10:07 AM
swizz977's Avatar
but if theres a welded nut y does it not feel tight but not just slide in back and forth because i cant get it out eather it just spins
swizz977 is offline
swizz977's Avatar
if the nut broke off wudnt it just come out easy
swizz977 is offline
Old 12-31-2011, 10:08 AM
Former User's Avatar
The nut could be stripped or broken or the bolt could be stripped. Post pictures.
Former User is offline
Old 12-31-2011, 10:34 AM
swizz977's Avatar
post pictures for what? im going to have to cut an access hole from eather inside or outside the car to get to that nut thanks
swizz977 is offline
Old 12-31-2011, 10:42 AM
The Grumpiest
You posted this nearly two months ago and you still have not gotten this taken care of?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ek-rear-camber-kit-install-broken-bolt-help-2898712/
Are you driving like this?
Old 12-31-2011, 11:05 AM
swizz977's Avatar
oh yea how would you take care of this huh??
swizz977 is offline
Old 12-31-2011, 11:12 AM
The Grumpiest
Can the attitude. You were offered many options. None of them of which you seemed willing to attempt or understand.
Originally Posted by apexi_rsx
http://www.ebay.com/itm/25-Rivet-nut...item5884670efa or here http://www.ebay.com/itm/STEEL-RIVET-...item89607911c7 here is some on eBay and its steel so u can weld it in as well. it actually doesn't matter what thread u get you can buy another bolt from ace hardware that has the same threads just take the rivet nut with u so you know u got the correct bolt and length. there are many m10 rivet nuts on there. i bought some a while back. make sure its steel so you can weld the outside of it in after u get it in there and set.
Originally Posted by 98civdx
Cut a hole, weld a new nut on , weld the cut peice back on.
they also make a thing called rivit nuts. it's an inserts that when u tighten the bolt down it mushrooms and locks the threaded insert in. like these http://www.rivetsinstock.com/rivet47.htm
Originally Posted by Killa82783
Inside the frame and most muffler shops or good mechanic shops can do something like this for pretty cheap.
Now you're asking the same question so the answers stay the same. Pick one and move on it. Just like before where you did nothing.
Old 12-31-2011, 11:30 AM
swizz977's Avatar
i dont think any of that is going to work where could i bring it to get a hole cut
swizz977 is offline
Old 12-31-2011, 01:12 PM
The Grumpiest
Old 12-31-2011, 01:15 PM
swizz977's Avatar
thats funny cuz i brought it to minakee they didnt do ****
swizz977 is offline
swizz977's Avatar
and i brought to to mavis same thing
swizz977 is offline
Old 12-31-2011, 01:16 PM
swizz977's Avatar
im thinkin this would be a restorations job wouldnt u?
swizz977 is offline
I would think this would be immediately obvious to most people.
Old 12-31-2011, 01:17 PM
swizz977's Avatar
i doubt any regular shops can do something like this the gas tank is very close too
swizz977 is offline
Old 12-31-2011, 01:18 PM
swizz977's Avatar
whats a picture going to do for u
swizz977 is offline
Old 12-31-2011, 01:19 PM
The Grumpiest
Jeez. Not a chain store. They aint gonna do nothing for you unless it's for something you bought from them. Find a local small shop. I don't care where you live there are plenty of those around. What did you do after you couldn't get it done at Meineke? You just sat and looked at it? Why are you making this 1000x harder than it has to be? Stop posting if you're not taking advice and know everything.
Old 12-31-2011, 01:21 PM
The Grumpiest
How do YOU know what a local shop can do? I bet you're driving around like this. The shops I go to can do anything I ask them to.
Old 12-31-2011, 01:26 PM
We can't see what you see. You don't seem very tech knowledgeable. You might be missing something important. Why resist something so simple that could help? Don't make it difficult for people to help you.
Old 12-31-2011, 01:30 PM
swizz977's Avatar
i doubt any shop u go to is going to wana cut a hole next to a gas tank..
swizz977 is offline
Old 12-31-2011, 01:33 PM
The Grumpiest
Like I said. You know everything. So I guess you're SOL.
Old 12-31-2011, 01:35 PM
Why create a tech thread if you are unwilling to take ANY helpful advice? This thread is becoming a strong candidate for closure after each of your responses.
Old 12-31-2011, 01:39 PM
canadaek's Avatar
quit being a bitch just cut the bolt off let the piece fall into the frame then use the rivit nut
or you can use a hole saw to cut the hole no sparks don't ask for help if your not going to listen to the reply's.
canadaek is offline
Old 12-31-2011, 01:53 PM
swizz977's Avatar
i dont have to cut the bolt off it comes out.. just need an impact gun
swizz977 is offline
Quick Reply: rear upper arm bolt question for 1992 civic
