B20b vtec
Old May 31, 2015 | 04:51 PM
Casey Holt's Avatar
Default B20b vtec
Hey guys im looking to swap my new motor in my 92 civic hatchback. I have 96-98 gsr wire harness, complete motor, and p72 ecu (obd2a). Im needing to know what exactly do i need to wire it up because the headlights are built into the 92 harness and not sure how to go about wiring it up. Any help will be appreciated.
Old May 31, 2015 | 04:59 PM
tony_2018's Avatar
Fish Twig
Default Re: B20b vtec
Is the gsr wire harness the engine harness? Should plug right up to the shock tower and all you would probably need is an obd1 to obd2a conversion harness.
Old May 31, 2015 | 05:00 PM
NotARaCist's Avatar
I never narc'd on nobody!
You don't need the GSR harness, nor do you have any use for the P72 ECU. What you do need to do is go read the FAQ sticky - it's quite obvious you have no idea what you're diving into.
Old May 31, 2015 | 05:04 PM
Casey Holt's Avatar
The harness and ecu came with the motor. ANd yes the gsr harness is 1 piece from ecu to engine
Old May 31, 2015 | 05:18 PM
NotARaCist's Avatar
So re-sell them both, recoup some of your money. Now, off to the FAQ sticky with you!
Old May 31, 2015 | 05:23 PM
Casey Holt's Avatar
Ha money isn't an issue I have enough to do the whole swap now in cash. And yea it may be more than I know but there's no need to come off as a dick.
Old May 31, 2015 | 05:32 PM
Former User's Avatar
Do some reading in the FAQs sticky. If you have unanswered technical questions thereafter, please create a new thread.
frankiecutz
Oct 31, 2015 03:49 AM
Hatchbacksonly
Nov 10, 2012 03:09 PM
Mikey3000
Jun 24, 2008 04:59 PM
36Chitownrunnin
Jun 9, 2008 09:28 AM
sleeprteg
Feb 26, 2007 08:32 AM
