92-00 Idle, what all can affect it.
Old May 27, 2015 | 09:37 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default 92-00 Idle, what all can affect it.
Hi all,
I've seen all kinds of idle things for out cars, the two most usual suspects are the IACV (all years 92-00) and the FITV (92-95).
However, every so often I seen other things suggested such as Coolant Temperature Sensor.
This got me to thinking, I don't even remotely know what all can affect idle on our Hondas.
I'd like to create a list of everything that can affect the idle of the car. Including to the uncommon ones and I'll make sure they go last on the list.
So here are the ones mentioned in this thread:
1)IACV - Idle Air Control Valve
2)Intake, Intake Manifold and Vacuum Leaks
3)Maladjusted Idle Screw
4)FITV (92-95 only) - Fast Idle Thermo Valve (I think the IACV will compensate some when this first starts acting up)
5)ECT - Engine Coolant Temperature sensor
6)TPS - Throttle Position Sensor
7)PCV Valve (92-95 typically) - Positive Crankcase Ventilation valve
8)Ignition/Mechanical Timing errors.
What else can cause idle problems with our 92-00 civics/del sols?
Oh, and I did look in the FAQ and for idle it only talks about the Set Idle Procedure, the IACV and the FITV. It doesn't even mention the ECT or anything else that maybe brought to light in this thread.
Last edited by TomCat39; May 28, 2015 at 06:34 PM. Reason: Updating post to include all knowledgeable input.
Old May 27, 2015 | 09:48 PM
Former User's Avatar
Default Re: 92-00 Idle, what all can affect it.
92-00 Civics:
IACV
Vacuum and intake air leaks
Misadjusted idle screw
ECT sensor
TPS
For 92-95 Civics, also add:
FITV
PCV valve
Old May 27, 2015 | 09:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
PCV Valve won't affect idle on 96-00?
tony_2018's Avatar
Fish Twig
idle problems? charging system, ac system?
Old May 27, 2015 | 09:56 PM
Typically not, because the OBD2 ECU is better at maintaining the proper idle speed with slight fluctuations (increased or decreased) of air intake.
Old May 27, 2015 | 10:01 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Sounds good, can the Intake Air Temperature Sensor (IAT) affect idle?
And what about the Manifold Absolute Pressure (MAP) sensor?
Old May 27, 2015 | 10:10 PM
Generally not.
Yes, but only indirectly by affecting engine performance. When you have MAP sensor problems, idle issues are generally the least of your problems.
Old May 27, 2015 | 10:22 PM
Originally Posted by tony_2018
charging system
Agreed, but again indirectly through general engine performance and not specific to idle system.
ac system?
True, but for an idle specific issue, it's an ECU (no idle up) rather than A/C problem.
When the A/C system itself causes idle problems, it's due to increased engine load (over-pressurized system or locked compressor).
Old May 27, 2015 | 10:36 PM
ECT - Engine Coolant Temperature sensor (I've seen this mentioned, don't know why it will affect idle)
The ECT sensor is critical for idle speed. Can you venture a guess?
Old May 27, 2015 | 10:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Thinking about it, I know it would affect fuel trim as it runs richer when cold as if the motor were choked.
As for idle, I'm drawing a loss at the connection.
Old May 27, 2015 | 11:07 PM
When the engine is cold, the engine idle speed is high. This happens because the ECU sees the low coolant temp from the ECT sensor. The ECU responds by telling the IACV to bypass more air to the IM, resulting in a higher idle speed. The idea behind the high idle speed when cold is to shorten the time for the engine to reach full operating temp, which is best for performance and fuel economy.
So now you can see why a goofed up ECT sensor or circuit can cause a goofed up idle.
Old May 28, 2015 | 01:36 AM
NotARaCist's Avatar
I never narc'd on nobody!
Slightly incorrectly set timing can also cause idle problems, from what I've seen.
Old May 28, 2015 | 05:34 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Mechanical or Ignition?
I'm assuming ignition as I think a tooth off in mechanical would pose more than just and idle problem.
Old May 28, 2015 | 08:56 AM
NotARaCist's Avatar
Both. If you use the wrong combination of belt/cam gear/crank gear on certain mini me setups, or even if a stock engine has had the head shaved too much, you can end up a quarter or half tooth off, which (under the right circumstances) can give a fucked up idle.
Old May 28, 2015 | 09:44 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good stuff, thanks.
BurgAccord95
Feb 16, 2009 06:30 PM
EJuno
Feb 5, 2008 06:20 PM
AZNracerx1989
Dec 14, 2005 12:01 AM
sporkcrx
Nov 9, 2002 06:59 PM
TurboCRVTEC
Oct 9, 2002 05:38 AM
