D to b series swap
Old May 21, 2015 | 04:25 PM
Jjoey13's Avatar
Default D to b series swap
So I'm planning on swapping a b16 into my 2000 civic. It has a d16y7 in it. I know I'll need a different ecu, engine harness, axles, but what else would I need? Would also be wonderful if you could specify where to get it from also.
Old May 21, 2015 | 05:54 PM
tony_2018's Avatar
Fish Twig
Default Re: D to b series swap
Check guides, stickies, google ek swaps....plethora of guides out there.
Old May 21, 2015 | 06:12 PM
DVDr's Avatar
if you go to hybrid section, it has all the information you need.
quick crash list.
engine
transmission
flywheel/clutch/pressure plate
3 new axels ( driver, passenger and half shaft )
exhaust manifold / header
b series shift linkage
driver side 2 bolt post ( from 99/00 civic si) ( you can keep the engine mounts )
rear transmission mount from 99/00 civic si
ecu to match engine
probably a conversion harness
rewire distributor
rewire iacv
add vtec wiring ( if going vtec b series , if going b18b or b20 , not needed )
radiator hoses to work with the skinnie stock rad, or upgrade to alu rad
added things you might need aswell
coolant
oil
oil filter
transmission fluid
ball joints ( if you wreck them during swap, or if they are old )
Old May 21, 2015 | 06:37 PM
NotARaCist's Avatar
I never narc'd on nobody!
Don't even have to go to the hybrid section. We have an FAQ sticky here that literally covers ALL of your questions.
Old May 21, 2015 | 10:01 PM
Former User's Avatar
Old May 23, 2015 | 06:48 PM
chrysler kid's Avatar
https://honda-tech.com/honda-civic-d...tions-1998336/
Old May 23, 2015 | 07:10 PM
Oaken81's Avatar
Sigh....
Use the search....
Krauthammer
Apr 17, 2019 08:59 AM
702SI
Jan 25, 2015 05:44 PM
Xcisions
Feb 19, 2013 06:25 PM
zach2004t
Jul 19, 2010 04:40 PM
aaronboy123
Apr 17, 2009 07:16 PM
