Classic Hondas All Pre-1988 Hondas.
negative camber fix???
Old Mar 26, 2015 | 05:30 AM
wagoslam's Avatar
Default negative camber fix???
1991 wagovan. Dropped 4 inches in the rear. Car obviously has negative camber, what's the easiest way to get back to stock stance? Will aftermarket lca's fix my camber issue? New to the honda game, please help!
Old Mar 26, 2015 | 02:10 PM
ej1995's Avatar
Default Re: negative camber fix???
ok, first of all, are you raising the car back up? you said back to "stock stance"
if so, then the camber issue should correct itsself. if you are staying low and wanting to correct the camber, then there are proper parts for that. do your research, its very simple.
Old Mar 26, 2015 | 06:28 PM
wagoslam's Avatar
Not raising it back up, just want 0 camber. Sorry for the confusion. So basically I slammed the rear of the car and it has negative camber. How do i go about getting it back to 0 camber?
Old Mar 27, 2015 | 08:48 AM
ej1995's Avatar
Google "1991 Honda Civic rear camber kit"
I feel pretty certain you will find the parts you need.
Old Mar 28, 2015 | 05:09 PM
wagoslam's Avatar
I've read nothing about bad reviews about camber kits... just replace lca's and it didn't get any better. alot of people said bushings but obviously that didn't help any other idea's or suggestions, or do you have any experience with camber kits?
Old Apr 24, 2015 | 07:46 PM
NW Classic Honda's Avatar
Wrong section, try the 88-91 Civic forum.
HondaCivic2006
Suspension & Brakes
Mar 22, 2009 07:20 AM
jdmkrazie
Nov 4, 2004 03:38 AM
AcCO12D95
Jun 12, 2004 10:48 AM
austrian type-R
Jul 23, 2003 07:42 AM
darkknightwong
11
Sep 18, 2002 09:41 AM
