negative camber fix???
1991 wagovan. Dropped 4 inches in the rear. Car obviously has negative camber, what's the easiest way to get back to stock stance? Will aftermarket lca's fix my camber issue? New to the honda game, please help!
Re: negative camber fix???
:thud:
ok, first of all, are you raising the car back up? you said back to "stock stance" if so, then the camber issue should correct itsself. if you are staying low and wanting to correct the camber, then there are proper parts for that. do your research, its very simple. |
Originally Posted by ej1995
(Post 50280089)
:thud:
Google "1991 Honda Civic rear camber kit"
I feel pretty certain you will find the parts you need. |
I've read nothing about bad reviews about camber kits... just replace lca's and it didn't get any better. alot of people said bushings but obviously that didn't help :crook: any other idea's or suggestions, or do you have any experience with camber kits?
Wrong section, try the 88-91 Civic forum.
