ok I'm swapping a d16z6 into a 2000 civic I have both complete cars I'm trying to make d16z6 obd2 . Which intake manifold should I put on the motor thanks
The fuel rail plug is an obd2 emissions plug, why would you need to worry about that with an obd1 motor? The plug in the back of the intake manifold? I don't know a plug in the back of the manifold but if you're talking about the iacv than thats not an issue either.
In fact I'm not even sure what ecu you are going to use to run the z6.
I'm making the motor obd2 everything that came with the 2000 is staying except the motor and no it's not the iacv but I'm using the y8 intake and we will see how it goes but thanks anyways
I got a 2000 civic ex with a d16z6 motor in it and it has a hunting idle and as soon as I give it some gas it dies. As far as I know the guy who did the swap left the ECU and harness in the vehicle and just swapped the motor. I can't not find any leaks and thinking it's some kind of communication issue. Any ideas?
Post a pic of the label on the ECU.
Also clean the IACV and FITV, and list the CEL codes stored in the ECU.
I'm sorry for the wrong info given. The iat code is there because I ran the vehicle with it unplugged. The only code I have is the map sensor code. It is reading at a little over 50hg.
i dont see any other connectors that are the same for me to have swapped but I'll double check.
The engine will also run poorly if the CKF by the crank gear is not connected.
Look for swapped sensor connectors by matching connector wire colors to sensors. If you don't have this information, post pictures of sensor connector wires for each sensor (IAT, IACV, MAP, TPS, ECT, PS pressure switch).
mos def need to 'trick' the ecu that the ckf is present.
Should I have got a dtc if there was no ckf like there was a code with the knock sensor ?
Ok sooo here is an update. I replaced the map because the reading was 52hg and just stayed there and never moved. When I replaced it the map code went away it was idling at about 1100 steady then I got a new code. P1509 . I have checked continuity between all wires to the iac. I didn't find any faults in the electrical. Can it be communication errors. I found this
The D16Z6 uses a 2-wire IACV. The D16Y7 uses a 3-wire IACV. Which IACV is installed?
On the harness is a 3 wire connector and the iac installed is a 3 wire connector. I wonder if they just swapped throttle bodies from a y7 motor so it would bolt and connect right up. If that is the case... Would that cause any issues?
