help with clutch
Old Feb 24, 2015 | 08:25 AM
xxxbat35's Avatar
Default help with clutch
96 civic b20b bottom with gsr head and 97 del sol trans. what type of clutch should I buy? and do I have to replace fly wheel too?
Old Feb 24, 2015 | 10:09 AM
grumblemarc's Avatar
The Grumpiest
Default Re: help with clutch
Resurface flywheel. Get an OEM replacement clutch like Exedy. You aren't pushing enough torque to warrant anything beefier.
Old Feb 24, 2015 | 10:26 AM
xxxbat35's Avatar
thanks for the info. while im sitting in my driveway with car running and clutch to floor I cant get into first gear but it when I try second as soon as I pull shifter car starts to roll forward but dosent want to go in gear. this happened last week then problem went away for a couple days now its back im assuming I need a clutch
Old Feb 24, 2015 | 08:20 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
^sounds like you need to bleed/check/fix the hydraulics and/or adjust the master cylinder.
It might be a clutch. But likely not. More likely a hyrdraulic problem since you're having an issue DISengaging the clutch.
Check if there's any fluid in your clutch master cylinder.
Old Feb 25, 2015 | 02:40 AM
xxxbat35's Avatar
Yeah I ordered new cmc and sc. Guess I'll wait n see
Old Feb 25, 2015 | 03:07 AM
NotARaCist's Avatar
I never narc'd on nobody!
How about instead of buying random ******* parts, you take 15 minutes to try to figure out what the problem is?
Old Feb 25, 2015 | 03:22 AM
xxxbat35's Avatar
Well I see some fluid on clutch pedal in cabin, n I do not have a garage n it below zero. I'll start with hydro first
Old Feb 25, 2015 | 05:11 PM
xxxbat35's Avatar
On second thought, go fly a kite!!
Old Feb 25, 2015 | 06:01 PM
NotARaCist's Avatar
Ya know, that's cute and all, but why are you even here if you're just going to throw random parts at it, no matter what we say?
Old Feb 25, 2015 | 06:12 PM
xxxbat35's Avatar
Just taking b _ serious advice. If I have to put a clutch in I'll have the Trans rebuilt too then the whole system will be new
Old Feb 25, 2015 | 06:38 PM
B serious's Avatar
But....why?
Old Feb 25, 2015 | 06:39 PM
B serious's Avatar
LOL. Respekt.
Old Feb 25, 2015 | 06:40 PM
xxxbat35's Avatar
Why not
Old Feb 25, 2015 | 06:47 PM
B serious's Avatar
Is there something wrong with the trans? An incorrectly done rebuild can cause problems. If its in good shape...leave it alone.
Mikeyb918
Oct 31, 2012 05:55 PM
favd21
Transmission & Drivetrain
Sep 8, 2012 03:00 PM
BlkCivicFromTeamMNR.com
Aug 15, 2009 09:29 AM
SlammedEH3
Dec 12, 2007 05:50 AM
TnLude2000
Feb 27, 2005 02:32 PM
