help with clutch
96 civic b20b bottom with gsr head and 97 del sol trans. what type of clutch should I buy? and do I have to replace fly wheel too?
Re: help with clutch
Resurface flywheel. Get an OEM replacement clutch like Exedy. You aren't pushing enough torque to warrant anything beefier.
thanks for the info. while im sitting in my driveway with car running and clutch to floor I cant get into first gear but it when I try second as soon as I pull shifter car starts to roll forward but dosent want to go in gear. this happened last week then problem went away for a couple days now its back im assuming I need a clutch
^sounds like you need to bleed/check/fix the hydraulics and/or adjust the master cylinder.
It might be a clutch. But likely not. More likely a hyrdraulic problem since you're having an issue DISengaging the clutch. Check if there's any fluid in your clutch master cylinder. |
Yeah I ordered new cmc and sc. Guess I'll wait n see
How about instead of buying random fucking parts, you take 15 minutes to try to figure out what the problem is?
Well I see some fluid on clutch pedal in cabin, n I do not have a garage n it below zero. I'll start with hydro first
Originally Posted by NotARacist
(Post 50226365)
Ya know, that's cute and all, but why are you even here if you're just going to throw random parts at it, no matter what we say?
Just taking b _ serious advice. If I have to put a clutch in I'll have the Trans rebuilt too then the whole system will be new
Originally Posted by xxxbat35
(Post 50228020)
(Post 50227922)
On second thought, go fly a kite!!
Why not
Is there something wrong with the trans? An incorrectly done rebuild can cause problems. If its in good shape...leave it alone.
