Want more power in a d16z6 what should i do?
Old Feb 11, 2015 | 04:31 PM
Blake_30303's Avatar
Default Want more power in a d16z6 what should i do?
Im looking to get more power out of my mototr only have headers and cold airintake
Old Feb 11, 2015 | 05:04 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Want more power in a d16z6 what should i do?
FAQ sticky. Go read it. Short answer: You won't, without actual power adders.
Old Feb 11, 2015 | 08:24 PM
Well im asking lik what should i add i only have a short budget
Old Feb 11, 2015 | 08:39 PM
Any specficet brands
Old Feb 11, 2015 | 09:34 PM
Jimi Hondrix's Avatar
Put money into stiffening the suspension and go faster around corners and turns.. even with bolt-ons your car still won't beat my granny's ride in a quarter mile with her driving it.
Old Feb 11, 2015 | 11:24 PM
NotARaCist's Avatar
First piece of sane advice ITT
OP, your car will not make more power with bolt-ons. If you drop a grand on the motor, it will be a comical waste of money. D series engines do not respond to bolt-ons. They just don't. They're economical grocery getters, made to move from point A to point B while using as little gas as possible and still being capable of reaching highway speeds. Putting an exhaust and an intake on a stock D series is like pissing yourself in black pants - you'll get a warm and fuzzy feeling, but no one else will notice. The few people who do notice will laugh at you, and soon, that **** will get cold, and you'll just be stuck wading around in your own cold, wet, ****-soaked pants.
Want to spend a grand on your engine? Save it. Spend it on hookers and booze - you'll have more fun, and a better story to tell than you'll ever get out of D series bolt-ons.
If you want your car to be more fun to drive, get a good suspension setup. What's "good"? Go read the FAQ sticky - there's a massive, well done post in there about the best setup for each price point. Want to go faster? Go read the FAQ sticky - there's another massive, well done post in there about how to actually make your car faster, not just leave you walking in your own ****.
Old Feb 12, 2015 | 02:41 AM
Great advice. I have a whole new level of respect for you NotARacist. I apologize for previously busting nards .
Old Feb 12, 2015 | 04:39 AM
Pacmane's Avatar
for d series turboing it is about the only way to see decent power gain. N/A is horrible for a d motor. Either turbo it or go b or k . that's your best choices
Old Feb 12, 2015 | 05:30 AM
angrysmileyface's Avatar
Sell the car and spend the money on one with a bigger motor or has a turbo. D-series as everyone says gets nothing with Bolt-ons. Its nice someone handed you a car, but to be honest, nothing will make a basic civic "Fast -n- Furious " without some serious tuning or modification, hence the term "Building an Engine"
Old Feb 12, 2015 | 08:39 AM
MyWhiteEJ6's Avatar
Originally Posted by BigPoppa420
suspension, but more importantly, TIRES. the better your car can grip the road, the more cornering Gs and the better the responsiveness. of course, tires and suspension go hand in hand....
Get yourself a K20 or K24
Old Feb 12, 2015 | 09:15 AM
Nave43's Avatar
Well i dont know what kind of car you have... but.... You dont have to "upgrade" the motor to make it faster. Maintenance goes a long way.
Short list of FREE things to make your D-Series faster:
Clean out that throttle body its easy and gives you better throttle response.
Tighten up your throttle cable. Its most likely loose, yet again throttle response.
Weight reduction, if you dont need it - GET RID OF IT!
(EX. I carry a tool box, a spare, and a jack, thats it, i have a full interior but a stripped trunk)
Set up an Icebox for what i am guessing is your short ram intake. (Highly doubt its a true CAI) You can make it out of milk jugs and zip-ties if you really "budget".
You wont see a HP gain but your motor will be happy.
Get rid of exterior antennas, and anything else that cause unnecessary drag.
Cut holes in the back bumper, will reduce drag when air pockets there at high speed.
Mods you can do for cheap:
Change out your fluids. New Dot 4 fluid for the brakes and clutch feels sensational. Don't forget about the trany fluid/oil for most people its the original fluid and after 150K it NEEDS changed.
Belly pan, Smooth out under your engine bay. Reduces drag and increases MPG as-well.
Fuel injector cleaner (Lucus Oil)
Buy a Paul Walker T-Shirt
Adjust valve timing, its free it just costs you a valve cover gasket.
Lower sub-frame U or H brace. Noticeably improves handling, and can be had for 25$
Expensive but worthy mods:
For the D-Series... Turbo... thats it. Maybe new cam?
B and K series swaps are most popular. I personally really like the H series 4WD setups.
GOOD BRAND suspension. Ebay coil-overs are throwing your money away
As has been said before. Tires
Thats all i got for now....
Old Feb 12, 2015 | 09:19 AM
tony_2018's Avatar
Fish Twig
Spend money on things to make it faster.
Old Feb 12, 2015 | 09:26 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
He gave you the best answer of all, go read the FAQ.
In the FAQ you will find "How do I make my car go faster?" which will give you a good indication of what you can do and you can research costs from there.
I'm closing this thread as you have gotten pretty much the best advise around already and there is no point in continuing this discussion any further.
Between the FAQ and what's already said in the thread there is nothing left.
eg6sittingon57cs
Aug 12, 2007 01:35 PM
Essenar83
38
Jul 4, 2006 07:00 PM
Syndacate
18
Apr 5, 2006 09:31 AM
hometheaterman
Oct 14, 2005 07:43 PM
Basically
Nov 6, 2004 08:52 PM
