94 honda civic d16z6
it start up an run fine. can let it idle as long as you want but when i drive it about 5 miles it starts busting up an cuts off an watn start till it cools down but been a few times it will start back up an run... everthing has been repalce on the dizzy new cap button new wires, new fuel filter, new main relay, an a bunch of other relays.. i am a lil confused on this dont know what else to replace..i have spark an fuel
all are good.. lights dont really go dim any at all... it will just start busting up an die then it takes about 30 mins will crank an run again... will idle as long as you want it to.. just when you drive it about 5 miles it dies
just about everything has been replace on all new hoses, wires, dizzy rebuilt, battery relocated to trunk with good wire, new fuel filter, fuel pump, regulator, relays
work was done by a professional on dizzy.. sometimes it will crank right back when it dies.... it start spittin an sputtering then die... sometimes it will crank right back up an some times take about 30 mins
found the problem bad wire on dizzy replaced the whole thing that i got out the junk yard runing better not cutting off but still no vtec an still feels like its loosing power then picks up on take off
eghatch9295
14
Jan 9, 2019 02:08 PM
Auxient
Jul 17, 2018 03:34 PM
