99' civic si won't start.........
Old Nov 1, 2002 | 02:59 PM
dsmith817's Avatar
Default 99' civic si won't start.........
last night i was at a stoplight, and as soon as i took off, my car died. i thought it was the fuel pump, so i replaced it. still won't start. checked the plugs, fine. checked spark.......no spark! replaced the ignitor and ignition coil. still won't start, and still no spark. lately the car has been taking a little more time than usual to start. just takes a few more cranks from the starter than usual. that's what made me think it could be the fuel pump. oh yeah, i am also getting fuel. i am not getting a check engine light. i'm thinking maybe it's the ECU??? i'm really stumped and would appericiate any help! thanks
Old Nov 1, 2002 | 03:33 PM
EVOCELICA's Avatar
New User
Default Re: 99' civic si won't start......... (dsmith817)
try replacing the cap and rotor, if you're not getting any spark it's a good chance it's something to do with the distributor.
Old Nov 1, 2002 | 03:38 PM
dsmith817's Avatar
Default Re: 99' civic si won't start......... (EVOCELICA)
the car only has 40000, the cap and rotor should be fine. i inspected them both and there isn't any substantial wear on either. i think it's gonna be something more complicated. thanks for the help though
Old Nov 1, 2002 | 03:39 PM
YumVTEC's Avatar
fuses, fuses, fuses
Old Nov 1, 2002 | 03:41 PM
dsmith817's Avatar
Default Re: 99' civic si won't start......... (YumVTEC)
checked all fuses. under the hood and in the cab. had a blown horn fuse. i replaced it. no difference
Old Nov 1, 2002 | 04:45 PM
EVOCELICA's Avatar
New User
well if I was you I would change the cap and rotor for sanity sake. It could be something that simple.
Old Nov 1, 2002 | 05:14 PM
FitCRX's Avatar
You thought it was the fuel pump so you replaced it with out checking? haha on 99? I have put a lot of miles on hondas...never had one break on me.
Old Nov 1, 2002 | 05:18 PM
FitCRX's Avatar
You thought it was the fuel pump so you replaced it with out checking? hahaha on a 99?hahaha I have put a lot of miles on hondas...never had a fuel pump break on me. Sorry...I know this doesn't help your problem...it has to be something simple...starter? battery...fuses
please post what was wrong when you find out...I'd like to know.
Old Nov 1, 2002 | 05:51 PM
Rob Dizzle's Avatar
Default Re: 99' civic si won't start......... (FitCRX)
check all of the wires
Old Nov 1, 2002 | 06:35 PM
dsmith817's Avatar
the fuel pump was bad. i did check it before i replaced it. otherwise i wouldn't have even bothered.
Old Nov 1, 2002 | 06:36 PM
dsmith817's Avatar
i put a distributor from a friends car on mine and it started up. found the problem. i'm goin to get me a new one. thanks to everyone for all your help.
Old Nov 2, 2002 | 07:17 AM
PnX-R's Avatar
THat's what I've done before and that's what I'll always do first.. Borrow a friend's part and see if it works on my car.. Good thinking!
Silver89crx
14
Dec 10, 2007 04:53 AM
dan89crxsi
Feb 10, 2007 02:44 PM
boostedpleasure
13
Oct 12, 2006 09:10 AM
vietjdmboi
Mar 8, 2005 06:33 PM
si00000
Nov 1, 2001 06:10 PM
