which rear mount? ys1 cable in 93 civic
Old Sep 19, 2014 | 07:06 AM
devinp52's Avatar
Default which rear mount? ys1 cable in 93 civic
I have had the car for a while and the rear trans mount is not the correct one only one hole lines up and I am trying to get everything on my car 100% correct.
Its a ys1 ls trans on a b18.
As far asi can tell someone bent\cut the civic rear mount to make one hole line up
Which mount is the correct one? The one from a 90 93 teg?
I have searched but can not find a firm answer.
Old Sep 20, 2014 | 02:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: which rear mount? ys1 cable in 93 civic
The proper bracket is from a '94-01 Integra. You will need to use the smaller 12mm bolts (17mm head) from the cable trans in the larger holes thru the bracket, but otherwise, all works as advertised.
existanzcivicb20
May 9, 2017 06:18 AM
CapnKrunch
Sep 1, 2010 07:19 AM
bap168
May 15, 2008 06:41 AM
93dabeast
Mar 15, 2008 10:23 AM
05 600RR
Apr 24, 2002 03:50 PM
