Been boosted <1 month and i'm thinking turbo change
Old Oct 31, 2002 | 12:07 PM
M.A.R.C.'s Avatar
Default Been boosted <1 month and i'm thinking turbo change
OK I slapped the turbo stuff on my car about 3-4 weeks ago. only running 6psi FOR NOW with a straight Garrett T3 (.48 a/r turbine, 60trim 60a/r compressor) on the d16y8. The spool up is like 3500-4k for 6-6.5psi. I'm somewhat dissatisfied with it though. I'm running a 2.5" downpipe to stock cat to 2.5" catback so I'm assuming the spoolup could be made better by getting a test pipe or highflow cat. The turbo I have is a used turbo, it's fine as it is now but I'm probably going to rebuild, upgrade (t3/t04b maybe), or get a new turbo setup (considering a mitsu 16G). I'm probably not gonna go all out on the sohc, probably only rods, pistons, blockgaurd, standalone and probably max street boost of say 12-14psi, possibly a little higher for track use. My question is. For the goal i just listed
12-14psi max on the street, prob 14-15 on race gas w/ standalone, what turbo would be a good choice for a d16y8 w/ 9:1 pistons and rods and blockgaurd?
I can't read compressor maps for **** really so that doesn't help.
thanks
Marc
Old Oct 31, 2002 | 02:22 PM
DLB1994's Avatar
Default Re: Been boosted <1 month and i'm thinking turbo change (CivicRyda2k)
t3/to4b with a .48turbine
Old Oct 31, 2002 | 02:26 PM
niedejb's Avatar
Default Re: Been boosted <1 month and i'm thinking turbo change (DLB1994)
I'd invest in tuning the one you have before opting for new one...if you havnt done so already.
Old Oct 31, 2002 | 02:34 PM
Midwestrider's Avatar
You want a T3 or a T3/T4 unit.
If a T3 look into a Super 60 trim, and if a T4/T3 look at a 50 trim on compressor w/ .48 a/r on exh.
Old Oct 31, 2002 | 06:49 PM
Drew Peacock's Avatar
Default Re: Been boosted <1 month and i'm thinking turbo change (Midwestrider)
Well you can up to 10psi with stock internals your gonna spend all that money for another 40hp you might as well be working your motor N/A style. Get good tuning and run 8psi evereyday 10-12 psi at the track stock block
Old Oct 31, 2002 | 08:53 PM
lazerus's Avatar
Default Re: Been boosted <1 month and i'm thinking turbo change (turbozxi)
6 psi on a t3/t04e what the hell you guys thinking...
Think Small! like mitsubishi 13G or a volvo turbo of some sort.
Old Nov 3, 2002 | 08:29 PM
M.A.R.C.'s Avatar
Default Re: Been boosted <1 month and i'm thinking turbo change (niedejb)
actually i just semi tuned it this weekend on a few dyno runs at John's (VaporTrail) Secret Services. I made 165whp and 140lb-ft @ 6psi on the T3 60 trim, .60 compressor, .48 turbine. not bad. i also had stock cat, and running directly off the wastegate (ie slower spoolup than if i had a ebc)
Old Nov 3, 2002 | 08:47 PM
SpoolnG2's Avatar
yeah, that trim and a/r does seem a little big for that motor. i'd say prally like a T3/04b with a stage II wheel..and a .48a/r..it would suit u better..anyone agree?
Old Nov 3, 2002 | 09:41 PM
CzanSOHC's Avatar
Default Re: Been boosted <1 month and i'm thinking turbo change (Jtsintegra)
I run a T3/T04e w/ a 50trim and 50A/R w/ my d167y.
96electronH
Nov 30, 2007 06:48 PM
EJ8 GSR-T
Mar 28, 2006 04:09 AM
Project_SOHC_EX
Feb 12, 2006 07:29 AM
killablaze
Nov 23, 2005 02:52 AM
hondanacura4life
Aug 16, 2002 05:58 PM
