AEM tru boost controler . Wiring pin out anyone help.
Hey guys picked up a tru boost controler for buddy but the wiring is missing wires in the 5 pin wiring.
If anyone can help.
Looking left to right I have
Black,red,black,blank spot, blank spot.
I need to know the power and ground and wires for boost silnoid thanks.
If anyone can help.
if you read i am missing wires .
So witch red is the Silenoid actuator ?? I have that pic and ive searched all over google !!!
Gotcha.
Using this picture as reference, the left pin of the 3 pin plug should be the red, the far right should be black, but there's a white wire in there, and it seems to...vanish.
Call AEM, and see if you can order just the harness. It'll make your life a LOT easier, and I can't imagine it being very expensive.
The 3 pin is for the extranal boost signal. There is a ground in the 5 pin they use to trigger the silenoid and I'm guessing it uses 12v switched all
Time !!
Time !!
I was gonna order but in canada looking at a week and customer needs car Monday.. The wiring harness is there just he cut the leads and all I have is 3 wires and I have tons of pin outs I can put in there.
Can you,just test it with a voltmeter?
Seems you,know you are looking for a switched ground. Should be very straight forward to test for it.
Customer cut the leads, customer has to wait for new leads to arrive. Business 101. It's not like you cut them. You could also call AEM, or go to their website, find a local distributor, and pick one up in person.
Excusetobooost
Sep 9, 2011 04:41 AM
