Honda Civic 97 AC PROBLEM... HELP!!!
Old Jul 26, 2014 | 09:40 AM
khriz306's Avatar
Icon3 Honda Civic 97 AC PROBLEM... HELP!!!
My ac was working fine but yesterday my radio was stolen and now the ac is not even blowing any air, the compressor is doing nothing. I have checked all of the fuses (the ones under the hood and the ones under the dash) but none of them were blown. The ac switch light wont come on but all of the others switches light work just fine. I think it has something to do with the cables behind the climate control because before the radio got ripped from the car everything was working fine.
Any help would be appreciated... thanks
Old Jul 26, 2014 | 09:55 AM
andoxviii's Avatar
Default Re: Honda Civic 97 AC PROBLEM... HELP!!!
Okay, so when they ripped out the radio, they cut a wire in the harness that plugs into your climate control. You said it yourself...
So just get in there and see which wire is cut and solder it back together.
Old Jul 26, 2014 | 10:07 AM
grumblemarc's Avatar
The Grumpiest
NOT an A/C problem. This is a wiring issue. As advised above, get in there and look for some damage.
Old Jul 26, 2014 | 10:11 AM
khriz306's Avatar
the thing is none of the cables are cut and all of the switches turn on (direction of the air switches) except the ac one. i checked all the cables none of them were cut.
Old Jul 26, 2014 | 03:31 PM
The Grumpiest
Don't think you checked hard enough. Possibly they damaged the climate controls.
Old Jul 26, 2014 | 06:09 PM
Haaarrrrryyy's Avatar
does your blower motor work in any of the fan speed settings? and about the a/c, id double check the wiring to make sure that none are damaged in any way. if you have a power probe, get to the connector on the compressor housing, unplug the harness, and manually power the compressor clutch to see if it engages. if to does, you probably have a wiring issue somewhere, or a bad switch, etc
MmacAttackK
May 31, 2013 07:42 AM
Dennis1
Honda Civic (2001 - 2005)
Jul 2, 2012 07:39 AM
ArmaanOG
Jun 28, 2009 09:14 PM
snowblind7x
Jul 3, 2006 11:20 PM
DreamCatcher
Sep 29, 2005 08:53 AM
