distributor problem need help ASAP!!!
Old Jul 21, 2014 | 03:26 PM
giovi_ek's Avatar
Icon6 distributor problem need help ASAP!!!
ok so i previeosly had my head done on my 97 ek hatch d16y7 with the engine open i set the #1 piston in top dead center then set the head bolted everything down put timing belt put the dizzy. now car hesitates on start and dosen't stay on when i let go of gas.
I HAVE TO DO THIS SO IT STAYS ON BUT HESITATES AND SOME TIMES MISSES
SORRY I DONT KNOW HOW TO POST PICTURES BUT HERE IS A LINK WHERE I HAVE A PICTURE
CAN SOMBODY PLIS HELP ME I NEED THE CAR FOR WORK
Old Jul 21, 2014 | 03:30 PM
grumblemarc's Avatar
The Grumpiest
Default Re: distributor problem need help ASAP!!!
Time it properly. The procedure can be found in the FAQs.
Old Jul 21, 2014 | 04:07 PM
andoxviii's Avatar
^^ Yeah, I agree. Sounds like your timing is off.
Old Jul 21, 2014 | 05:18 PM
giovi_ek's Avatar
By how much the timing is of? And which way do i jump tooth or set it
Old Jul 21, 2014 | 05:20 PM
The Grumpiest
How are we supposed to know?
Old Jul 22, 2014 | 04:51 PM
giovi_ek's Avatar
Iam trying to set timing but crank bolt wont break loose so i cant take the pulley out i have tried a 900lb impact gun with 125psi tank and it still dont come out any ideas please help
Old Jul 23, 2014 | 04:26 AM
09chaplak's Avatar
Loves Tossing Salad
Breaker bar with some other goodies should do it........https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-removing-your-crank-pulley-898904/
Old Jul 23, 2014 | 04:28 AM
09chaplak's Avatar
Loves Tossing Salad
You'll also probably want to check out the section on how to PROPERLY seat the timing belt, it doesn't just go on looking fine. Methods to the madness
Old Jul 23, 2014 | 02:53 PM
giovi_ek's Avatar
thanks to all car is running perfect now thanks for ur time
Hondatastic
Aug 19, 2016 02:58 PM
Timberland237
Sep 6, 2007 05:51 PM
bOOsTiNSoHcVtEc
Aug 12, 2005 02:21 PM
bOOsTiNSoHcVtEc
Aug 11, 2005 03:41 PM
jetpilot
14
Sep 25, 2003 11:18 AM
