distributor problem need help ASAP!!!
ok so i previeosly had my head done on my 97 ek hatch d16y7 with the engine open i set the #1 piston in top dead center then set the head bolted everything down put timing belt put the dizzy. now car hesitates on start and dosen't stay on when i let go of gas.
I HAVE TO DO THIS SO IT STAYS ON BUT HESITATES AND SOME TIMES MISSES
SORRY I DONT KNOW HOW TO POST PICTURES BUT HERE IS A LINK WHERE I HAVE A PICTURE
CAN SOMBODY PLIS HELP ME I NEED THE CAR FOR WORK
Re: distributor problem need help ASAP!!!
Iam trying to set timing but crank bolt wont break loose so i cant take the pulley out i have tried a 900lb impact gun with 125psi tank and it still dont come out any ideas please help
Loves Tossing Salad
Breaker bar with some other goodies should do it........https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-removing-your-crank-pulley-898904/
Loves Tossing Salad
You'll also probably want to check out the section on how to PROPERLY seat the timing belt, it doesn't just go on looking fine. Methods to the madness
Hondatastic
08-19-2016 02:58 PM
