Re-install AC
I am looking to get a 92 civic si with a f20b motor swap in it. If I was to reinstall AC into the car (it has the lines going to blower in the car and such) what all would I have to re-install? Also where would I get them, and would they be for the 92 civic or the f20b motor car (accord I believe?). Thanks guys, just hoping it won't cost too much :-/
what you will need to install depends on what is not there now...
I think you may have two options. one is to use all civic components and buy a special mount bracket to bolt the civic compressor to the F20. see this link
the other possibility is to use an accord bracket and compressor with custom flex lines from the compressor to the rest of the system. I only know about this working in theory. you'll need to do some more research to get the real story.
Do you know if the bolt to the compressors are all the same? If I can get the components for my civic and bolt it into the accord compressor that would probably be easiest....but I think the no power steering is getting annoying already lol. I was going to look into electrical power steering. I think a Toyota MR2 had this type of setup.
what's your set up? hoses removed, looped, "de-powered"? the feel is quite different between the three. also your scrub radius (which is effected by non-factory offset wheels) tire pressure, tire width and type of tire can all have a negative effect on steering feel.
i would guess they are the same, but to check for yourself go to a site like hondapartsunlimited.com and compare the specifications indicated on each schematic.
kensei
11
Jun 14, 2009 10:11 PM
DIRep972
Mar 31, 2004 07:35 AM
