Safe RPM for my build
What would be a safe maximum RPM for the following build
Going to run boost at between 20 to 22 pounds
Gear box is built JDM Y1 cable quaife
1st 3.166
2nd 2.052
3rd 1.416
4th 1.103
5th 0.870
FD 4.266
B18C1
Stock sleeves 81mm
Eagle Rods
CP 9:5:1 pistons
ACL and ARP hardware throughout
Stock ITR head, cams and valve train
Garret
Turbine
- Wheel: 53.85mm w/ 76 trim
- Housing: .86
Compressor
- Wheel: 71mm w/ 56 trim
- Housing: .60 A/R
Turbine clipped for more flow as the 76 trim is a bit restrictive on the 2871.
1st 3.166
2nd 2.052
3rd 1.416
4th 1.103
5th 0.870
FD 4.266
B18C1
Stock sleeves 81mm
Eagle Rods
CP 9:5:1 pistons
Garret
Turbine
- Housing: .86
Compressor
- Housing: .60 A/R
With a stock type R valve train it would most likely be pointless to rev much past 8800-9000 rpms. You pretty much need to put the car on a dyno and see where your car stops making power. If you do make power past 9000 rpms I would upgrade the springs.
My concern is more the amount of boost being run coupled with the RPM's and the stock sleeves as I fear that high RPM's and higher levels of boost may be bad for the sleeves.
I had the same fears and upgraded the valve train, and had a CNC Werx CSS installed this time around.
hmmm interesting comments, I never run the RPM's above 8800rpm and right now I'm stuck with stock sleeves, which I guess is going to be a lottery at the boost level, just the combination or boost and RPM's and where to cap them for safety sake.
If the head is stock don't rev past stock redline. The turbo isn't large enough to have a need to rev higher. It's not going to make power higher in the rev range with this setup anyway. Personally for couple Hundred bucks slap in some springs and retainers for safe measures. Stock valves will be fine for higher rpm with your setup.
Who is Mr Robot?
you should only turn the motor to the point where power drops off... anything higher than that serves no purpose unless you have to rev higher so that when you change gears you're in the meat of the power band.
you should set your shift points for each gear so that the rpm drop between each gear puts you where you're making the most torque.
I understand shift points and working outside the turbo's efficiency range, I've been running the turbo at 16 psi and take the RPM's to 8800 and all has been well, I know the turbo's power band should reduce as I increase the boost but initial indications are showing that the turbo still wants to make power into and about 8800rpm on this particular unit. PCP's coupled with high rpm's are my main concern for the sleeves, from what you guys are saying I need to worry more about the valve train than the sleeves.
Who is Mr Robot?
As long as you don't have any issues with detonation you should be fine. a smooth increase in cylinder pressure won't break sleeves (within reason obviously). it's the sudden peaks from detonation that crack sleeves.
if you only turn to 8800 I don't imagine you'd have to shift higher than 9200rpm at most to stay in your powerband
ive heard 9200 is the end of the efficiency range for boosting on these..
i myself only run it up to stock redline, even though ive done the crower valve springs with titanium retainers...although i might bump up the redline some in the future..
To be honest I have no reason to rev out beyond 8800 I'm currently crossing the line at the 1/4 at 123mph (11.57) on 23/15 H&H slicks that's running the turbo at 15 psi I want to run a low 11 or if possible a 10 with the same set-up hence why I wanted to increase boost.
I think I will change the valve train for piece of mind but I have no aspirations to go any further with the car in terms of 1/4 mile times just going to enjoy it, well maybe
Who is Mr Robot?
Err yeah 9200 on stock springs is a bad idea. not only is there a very real valve float issue to begin with but boost pressure also reduces the effective spring rate of the valve spring so it will float sooner.
I wouldn't go over 8800 period for the sake of longevity. want to rev higher then get a stiffer set of valve springs.
Who is Mr Robot?
For a car that sees mostly street miles a set of tool steel retainers would last much longer... and they only weigh a few grams more than titanium at a 1/4 of the cost.
EF9_TryMe
Nov 2, 2011 06:43 PM
bboyoxygen
Jan 22, 2005 08:37 PM
1.8T_EG
Feb 5, 2003 12:52 PM
