!!!!TURBO B18C PROBLEMS HELP PLEASE!!!!
Old May 14, 2014 | 03:02 PM
Chandler_C's Avatar
Default !!!!TURBO B18C PROBLEMS HELP PLEASE!!!!
Hi everyone I'm having some issues with my turbo b18c1 with 6k miles on the rebuild. I was told by the previous owner that it had a valve problem because he floated a valve, But I'm not sure.
The issues Im having:
1. Cylinder 4 has low compression. came to around 60psi, all other cylinders are good. Did a leak down test and air came out through the oil cap.
2. Has a rough idle. Sometimes idle sticks around 2k rpm then randomly drops back down.
3. Smokes out of oil breather and the dipstick hole when i remove it.
The car still starts up and runs fine, but the car is not running right when i get into boost.
If anyone could please help give input on these problems that would be great.
I dont know what it could be and trying to get an idea of what I'm up against.
Thanks in advance.
Old May 14, 2014 | 03:34 PM
Fliptard's Avatar
Default Re: !!!!TURBO B18C PROBLEMS HELP PLEASE!!!!
wouldn't a blown headgasket cause the leak down to go thru the coolant system, seeming's how it has to pass the coolant passages to get to the oil passages.
Old May 14, 2014 | 04:41 PM
Chandler_C's Avatar
Could bad piston rings cause any of this? i hope its nothing in the block.
Old May 14, 2014 | 04:43 PM
Fliptard's Avatar
I would more go toward the rings. There is no other way the leak down would get into the oil area ( coming from oil cap) besides the rings.
Old May 14, 2014 | 04:49 PM
Chandler_C's Avatar
alright thanks for the input man, but could that cause all the problems im having like the rough idle and the low compression?
Old May 14, 2014 | 04:54 PM
myEKsedan's Avatar
the rough idle your having is due to low compression in that one cylinder. do yourself a favor and stop driving it till its fixed
Old May 14, 2014 | 04:58 PM
Chandler_C's Avatar
Yea the car has been parked since i got it. Im just trying to get an idea what the problem is before i take it apart.
Old May 14, 2014 | 05:13 PM
Chandler_C's Avatar
And will replacing piston rings need a rebuild? or can i just replace them.
Old May 14, 2014 | 05:57 PM
grumblemarc's Avatar
The Grumpiest
The head's coming off regardless. Start wrenching. Leakdown tests should tell you exactly where it's happening.
Old May 14, 2014 | 05:59 PM
Chandler_C's Avatar
Already started lol
Old May 14, 2014 | 06:03 PM
The Grumpiest
Oh whelp. Too late for a leakdown.
Old May 14, 2014 | 06:12 PM
Chandler_C's Avatar
I already did a leakdown test. The air blew out of the oil cap hole.
Old May 15, 2014 | 05:36 PM
turbohatch96y7's Avatar
Drop the oil pan and windage tray and take a look at the underside of the pistons. I broke a ring land on my ls and I seen it from underneath after I looked at the tops with a scope
Old May 16, 2014 | 12:50 PM
The Grumpiest
Derp. Saw that right in the first post.
What have you found?
Old May 16, 2014 | 02:10 PM
1HGEJ2's Avatar
bad pistonring or brake the stage between ring 1 and ring 2
had the same problem on cyl 4. and smoke out of breather. oem pistons or aftermarket?
Old May 17, 2014 | 04:48 PM
Chandler_C's Avatar
Yea mine was cylinder 4 also. I have JE pistons in it.
Just got it all apart and checked the stuff out. The pistons are melted and the bottom side of head in cylinder 4 is beat up from melting. Must have been running too lean. All the valves were fine. thanks for all the input though guys!
Sprockets
Oct 5, 2017 06:37 AM
thekid2390
Apr 11, 2013 09:13 PM
derka_si
May 24, 2012 12:55 PM
hammerj2
Mar 18, 2010 06:24 AM
99TurboFerio
Oct 13, 2005 03:02 PM
