climate control switch problems
Old Apr 30, 2014 | 08:14 PM
707Bay's Avatar
Default climate control switch problems
Lever for the blower speed feels loose and blower always runs on full blast. could anyone guide me to solving or finding what could be causing this? bad wiring?
1995 civic EG8
thanks in advance
Old May 2, 2014 | 12:36 AM
turbomaniac's Avatar
Default Re: climate control switch problems
it must be the lever..
check the lever's connections..
replace with a working lever
Old May 4, 2014 | 11:01 PM
SpokaneSpeed's Avatar
Could just be worn out and loose - the fan only working on high could be the blower motor resistor as well...
Old May 5, 2014 | 04:24 PM
707Bay's Avatar
Well thanks guys, I did more digging and I found out that the ground cable of the blower motor was cut and reground using another cable?? Do no why they would do that? Could it be that the bypassed it due to the lever speed not working?
Old May 6, 2014 | 01:51 PM
mabe they somehow bypassed lever becaused didnt funcion well
if the reground is well tightened or well wired to another ground you souldnt worry.
I would start with a used lever switch and than would make the wirings exactly as they should be with a proper wiring diagram
Old May 6, 2014 | 01:54 PM
yeah but it looks more than wiring s...t stuff or lever.
i say this because it seems some previous owner has put his finger to the wirings...
Old May 7, 2014 | 11:28 AM
fcm's Avatar
fcm
Old Fart
It is a good bet the switch is bad and the PO wired the blower motor to ground so it would work, on/off and speed is controled by the blower speed switch/lever, full grounf for fast speed and through 1 or more resistors, [blower resistor] for the slower speeds,
It sounds like only the switch is bad and the blower resistor is good as the fast speed would still work if the problem was the blower resistor. 94
Old May 9, 2014 | 09:24 PM
707Bay's Avatar
Wow thanks very much guys big big help. I'll let you guys know what it was.
JONESn'
Feb 15, 2013 01:21 PM
SHell_
Jan 28, 2010 09:57 AM
Dbach
10
Nov 11, 2008 06:28 AM
skateboard
Feb 9, 2007 11:23 AM
eric712
Jun 9, 2002 07:20 PM
