Fully built b16 turbo option
Just had a quick question on what turbo you guys would suggest with my set up. Here are the parts for my motor.
Cp pistons 9:0:1
Brian crower rods
Apexi headgasket 1.5mm 82 bore
Skunk 2 pro series valves
Darton sleeves
Arp headstuds
Comp stage 4 clutch
Aem cam gears
I'm curious what I could make on this setup, I'm hoping for 450-500 any suggestions on what you guys think it would make and any other parts I should pick up would be cool. Thanks!
Cp pistons 9:0:1
Brian crower rods
Darton sleeves
Arp headstuds
Comp stage 4 clutch
Aem cam gears
you have very low CR, about 8:1 with that 1.5 mm gasket
with your setup i would use a GTX3071R if you want responce from 4000 rpm , or GTX3067R if you want responce from 3500 rpm.
more or less x3071 will make 500 at 25psi and X3067 500 at 30psi
