Fully built b16 turbo option
Old Apr 30, 2014 | 06:30 AM
dylthomas's Avatar
Default Fully built b16 turbo option
Just had a quick question on what turbo you guys would suggest with my set up. Here are the parts for my motor.
Cp pistons 9:0:1
Brian crower rods
Apexi headgasket 1.5mm 82 bore
Skunk 2 pro series valves
Darton sleeves
Arp headstuds
Comp stage 4 clutch
Aem cam gears
I'm curious what I could make on this setup, I'm hoping for 450-500 any suggestions on what you guys think it would make and any other parts I should pick up would be cool. Thanks!
Old Apr 30, 2014 | 06:41 AM
turbomaniac's Avatar
Default Re: Fully built b16 turbo option
you have very low CR, about 8:1 with that 1.5 mm gasket
with your setup i would use a GTX3071R if you want responce from 4000 rpm , or GTX3067R if you want responce from 3500 rpm.
more or less x3071 will make 500 at 25psi and X3067 500 at 30psi
Old Apr 30, 2014 | 06:56 AM
dylthomas's Avatar
Thanks! Really like the gtx3071r will probably pick that up!
dylthomas
May 11, 2014 11:28 AM
Jdm_Ej8_Sedan
Feb 8, 2014 01:55 PM
dommyy13
Oct 3, 2012 11:17 AM
sean7001
May 11, 2007 01:19 PM
Mr. Em1
Apr 15, 2006 02:02 PM
