f23a4 turbo project
Old Apr 27, 2014 | 05:18 PM
Accord4Life1990's Avatar
Default f23a4 turbo project
Gonna build my 6th gen accord for a turbo. Wonder which brand would be best and cost efficient. Help please.
Also thinking about a bodykit....maybe a gt-r34 kit. Opinions
Old Apr 27, 2014 | 07:43 PM
94 accord typeR's Avatar
Default Re: f23a4 turbo project
not sure but apexi greddy and hks might have turbos
Old Apr 28, 2014 | 06:48 AM
mrj_accord's Avatar
u can use ebay piping and intercooler. nothing else from ebay!!!
blow off valve (bov) - you can look into HKS, synapseetc.... no ebay brands
wastegate - tial, turbonetics..... no ebay brands
turbo - greedy, turbonetics, precision....... u guessed it, no ebay brands
ur gonna need bigger injectors, fuel rail, fuel regulator, engine management, turbo timer, electronic boost controller, a/f gauge, boost gauge, oil pressure gauge, clamps, exhaust manifold, custom downpipe, better (bigger) flowing exhaust and a good tuner.
i might have left something out but i'm sure someone else will add it.
my advise is to piece a kit together than buying a complete kit. usually a complete kit might have an inferior peice that u wanna upgrade and will cost u more. piecing a kit will get u exactly what u want and need.
before u head down this road u need to have an idea of what ur power (hp) goals are. this will determine the cost of ur build. hopefully u have a 5sp because an auto will limit ur hp goals (this is my problem right now). the auto tranny in this gen is pretty bad.
u need to read up on alot of turbo info and when u think u got it, reread it.
now onto the bodykit, its ur car and u do what would make u happy cause its ur build. me personally i would pass on it.
boost is contagious and addictive u will want more!!!
Old Apr 28, 2014 | 10:03 AM
Thanks. Do I need a full size intercooler or will a mini intercooler work?
Old Apr 28, 2014 | 10:19 AM
mrj_accord's Avatar
that depends on how much power u plan to put down. if ur not planning serious power and i'm talking about over 400hp then a small intercooler is good.
Old Apr 28, 2014 | 10:23 AM
Alright thanks. Just planning on reaching between 200-250. Gonna be a daily driver and a small toy.
Old Apr 28, 2014 | 10:58 AM
mrj_accord's Avatar
gotta be careful with the piston rings. those are also a weak point on a turbo build.
when i did my build i have everything done. new turbo pistons, rods, valves, valvesprings and retainers and cam. also ARP headstuds so the head wont lift from the block during boost.
if ur planning to go this route also u might want to look into bisimoto.com for aftermarket engine parts.
with a good tuner u can run stock internals
Old Apr 28, 2014 | 12:16 PM
How much boost are you running and what engine and style accord is it on.
Old Apr 28, 2014 | 12:41 PM
mrj_accord's Avatar
5th gen with a B1 engine. currently running 10lbs of boost making 250hp to the wheels, 300hp at crank
here is my intro thread with pics.
https://honda-tech.com/forums/introduce-yourself-162/my-intro-tired-lurking-3163199/
Old Apr 28, 2014 | 01:59 PM
That's pretty nice. I didn't know 10 lbs of boost would raise the hp that much.
Old Apr 29, 2014 | 06:53 AM
mrj_accord's Avatar
it depends on the turbo not on how many lbs ur running. i can get a smaller turbo and it will spool up faster at 10lbs but not get u to the same hp gains. also depends on the tuner and his tune.
Old Apr 29, 2014 | 07:04 AM
Oh alright. As you can tell this is mostly new to me.
My cousin has a set of srt4 500cc injectors and says they will work in my f23a4 vtec. Do you have knowledge if those will fit and work right?
Old May 1, 2014 | 04:52 AM
did you use stock piston rings or did you get upgraded one? and using stock on your turbo engine, have they held up pretty well or have you had to replace? If they are upgraded ones then what brand are they?
Old May 1, 2014 | 05:41 AM
mrj_accord's Avatar
engine internals are all from bisimoto.com
they have a piston and rod combo with ceramic coating that i ordered from them.
also valves, valve springs, retainers, seats and stage 2 cam. aem timing gear, aem fuel rail and pressure regulator. S300 for engine management. greedy turbo timer and elec boost controller
Old May 1, 2014 | 06:38 AM
alright thanks. just want to have a strong enough build so i dont blow my engine.
dc101
Sep 30, 2011 06:38 AM
ryanangelo212
Jul 7, 2010 11:53 AM
jlfrnce
Feb 1, 2007 07:55 AM
ThatsTheTruth
May 12, 2006 08:02 AM
