d16y7 block and head with B7 intake iac problems
Old Apr 19, 2014 | 07:55 AM
RaistlinJDM's Avatar
Default d16y7 block and head with B7 intake iac problems
i put a b7 intake on my y7 and converted the iac plug to a 2 wire and moved the pin in the ecu to the 12 spot and now my car wont idle unless i have my foot on the gas any help would be great!!!! im running the factory p2e ecu
Old Apr 19, 2014 | 08:06 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: d16y7 block and head with B7 intake iac problems
Did you replace the throttle body as well, or did you just bolt the Y7 TB on the B7 IM?
Old Apr 19, 2014 | 10:10 AM
i used the b7 throttle body and iac
Old Apr 19, 2014 | 10:32 AM
NotARaCist's Avatar
Check your throttle cable tension (it should have some play with your foot off the gas pedal). Also, check to make sure your throttle plate isn't closing flush - if someone fiddled with the stop screw, you're going to play hell getting it to idle right.
Old Apr 19, 2014 | 02:46 PM
adjusted the stop screw and tps and it idles better now but it has a stutter at minimum throttle application now
Old Apr 19, 2014 | 02:54 PM
Former User's Avatar
Any CEL codes?
Old Apr 19, 2014 | 06:09 PM
iac bad circuit
Old Apr 21, 2014 | 06:10 PM
still have a fluxuating idle at about 1500 rpm and the power lurches at low throttle
mgags7
Jan 30, 2025 08:58 AM
TonyRomo
Apr 30, 2009 07:06 PM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
LilManSi
Jan 26, 2004 04:12 PM
