d16y7 block and head with B7 intake iac problems
i put a b7 intake on my y7 and converted the iac plug to a 2 wire and moved the pin in the ecu to the 12 spot and now my car wont idle unless i have my foot on the gas any help would be great!!!! im running the factory p2e ecu
I never narc'd on nobody!
Re: d16y7 block and head with B7 intake iac problems
Check your throttle cable tension (it should have some play with your foot off the gas pedal). Also, check to make sure your throttle plate isn't closing flush - if someone fiddled with the stop screw, you're going to play hell getting it to idle right.
mgags7
12-07-2023 10:36 AM
import-tooner
07-03-2013 07:49 AM
Mr. JDM-GSR
08-29-2005 11:33 AM
