Fast Clicking Trying to Start
Old Apr 6, 2014 | 03:35 PM
nothing_shocking's Avatar
Default Fast Clicking Trying to Start
I've tested the starter (8 times in a row at Advance), the alternator (took battery cable off with car running), battery (tested at Advance), and the clutch switch (paper clip jump). Also tried adding more grounds (used jumper cables).
Car push starts just fine and runs perfectly. Didn't start having this problem until I changed the oil and put in a new o2 sensor.
Old Apr 7, 2014 | 07:54 AM
98civicboy69's Avatar
Default Re: Fast Clicking Trying to Start
check your grounds....EVERYWHERE. mine did the same thing and was just a ground wire that broke off.
Old Apr 7, 2014 | 08:24 AM
Valve cover wire, tranny to body, battery to body. That's it right? All 3 are in good shape, and like I said in the op, I added extra grounds and that did nothing. Edit: And the thermostat housing ground. I can feel the clicking in the starter if I put my hand on it.
Old Apr 7, 2014 | 01:42 PM
95Sedan's Avatar
yeah check grounds, put a new battery in it see what happens..
Would replace battery terminals if anything.
Old Apr 7, 2014 | 01:50 PM
testify's Avatar
On vacation
Sounds like a dead battery.
Old Apr 7, 2014 | 01:51 PM
24TEN's Avatar
PHANTOM MENACE
X2
For the sake of verifying, how old is the battery? It should have a year/month on it.
Old Apr 7, 2014 | 02:55 PM
Nickytalon's Avatar
New to the honda game, But had a issue like this on a different car & it was the relay for the starter.
Old Apr 7, 2014 | 04:11 PM
10/12 is the battery date. I put new brass terminals on a month ago.
Old Apr 7, 2014 | 04:16 PM
crazyhouse2011's Avatar
You removed the battery from the system to verify the alternator was working while the car was running?
R.I.P ECU.
Maybe next time have them TEST IT at the advance auto you went to to test the starter.
Old Apr 7, 2014 | 04:44 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
There is also the ground on the thermostat housing. G101
Old Apr 7, 2014 | 05:07 PM
carlos8's Avatar
Mine do the same once, put a new battery and sometimes still do the same.
With the new battery and a new ground from the starter bolt to body, fixed.
Old Apr 8, 2014 | 05:02 AM
Never once had a problem testing the alternator that way. If it refuses to start one day, I can come back a couple days later and it'll start. Another reason I don't think it's the battery.
Old Apr 9, 2014 | 09:51 AM
Hilariously, it ended up being a junk battery... It wasn't holding a charge. Free replacement from advance and everything is good again.
xjm92x
16
Mar 22, 2011 02:58 PM
dudee
Nov 23, 2010 07:34 AM
gooberwolf
Mar 9, 2009 04:11 PM
B18 CYA
Oct 29, 2004 07:59 PM
Heavy Pee
Jul 21, 2003 08:32 PM
